    Fix Windows 10 Update Issues
HP LaserJet M4345 Multifunction Printer Series - Replace the Staple Cartridge
To view a video demonstrating the procedure for removing the part click here to access the Services Media Library (www.hp.com/go/sml). Select Printers and Multifunction under the Product category, select HP Color LaserJet Printers under the Product family, and then select the printer model under the product series category.
Staple cartridge replacement
  1. Press and hold the release button on the top of the stapler/stacker. Pull the stapler/stacker away from the MFP.
  2. Open the staple-cartridge cover.
  3. Grasp the green staple-cartridge handle and pull the old staple cartridge out of the stapler unit.
  4. Insert the new staple cartridge into the stapler unit and push down on the green handle until the unit snaps into place.
  5. Close the staple-cartridge cover, and slide the stapler/stacker into the MFP.
Parts return
