Document ID: c02738270
Version: 1
HP EliteBook 8440w Mobile Workstation and HP EliteBook 8440p Notebook PC System BIOS Update F.12
Release date : 01-Mar-2011
Last updated : 02-Mar-2011
DETAILS OF CHANGE
Field issue fixes:
  • Improved the BIOS flashing algorithm to minimize a BIOS corruption issue.
  • Fixed an issue where the the BIOSConfig utility could not change the "Virtualization Technology" field in F10 Setup.
  • Fixed an issue where the battery check utility reports an incorrect battery warranty period.
  • Fixed an issue where the computer could not boot with Boot Star Boot Manager. Note: This issue only occurs with Microsoft Windows XP SP3.
REASON FOR CHANGE
To implement changes under "Details of Change."
IMPACT OF CHANGE
None.
Components affected:
DATE OF CHANGE
Effective date : 04-Apr-2011
Hardware platforms affected : HP EliteBook 8440p Notebook PC, HP EliteBook 8440w Mobile Workstation
