HP LaserJet Enterprise P3015 Printer Series - Replace the Print Cartridge
To view a video demonstrating the procedure for removing the part click here to access the Services Media Library (www.hp.com/go/sml). Select Printers and Multifunction under the Product category, select HP Color LaserJet Printers under the Product family, and then select the printer model under the product series category.
Print cartridge removal
  1. Press the top-cover release button, and open the top cover.
  2. Remove the used print cartridge from the product.
  3. Remove the new print cartridge from the bag. Place the used print cartridge in the bag for recycling.
  4. Grasp the front and back of the print cartridge, and distribute the toner by gently rocking the print cartridge five or six times.
    Do not touch the shutter or the surface of the roller.
  5. Remove the shipping tape from the new print cartridge. Discard the tape according to local regulations.
  6. Align the print cartridge with the tracks inside the product, and insert the print cartridge until it is firmly seated.
  7. Close the top cover. After a short time, the control panel should display Ready.
Parts return
