The language on the control panel display is not the expected language.
- ${title}
- ${title}
- ${title}
- ${title}
HP Deskjet 3050A and 3070A e-All-in-One Printer Series - Display Is in the Wrong Language After Setup
Issue
Solution
Follow these steps to reset the language and region on the product.
On the product control panel, press the Setup button (
Press the button (
) next to the Down Arrow (
) to scroll to Set Language, which is the fifth option that displays on the control panel.
Press the button (
) next to OK to confirm your selection.
Press the button (
) to scroll through the languages.
Press the button (
) next to OK, and then select Yes to confirm the language choice.
Press the button (
) to scroll to Set Region.
Press the button (
Press the button (
) to scroll through and select your desired region.
Press the button (
) next to OK, and then select Yes to confirm the region.
Additional support options
- ${title}
- ${title}
- ${title}
Country/Region:
Serbia
- ${title}
hp-hero-support-search
- ${title}
