    Fix Windows 10 Update Issues
HP LaserJet 5200 Printer Series - Replace the Transfer Roller
To view a video demonstrating the procedure for removing the part click here to access the Services Media Library (www.hp.com/go/sml). Select Printers and Multifunction under the Product category, select HP Color LaserJet Printers under the Product family, and then select the printer model under the product series category.
Transfer roller replacement
  1. Open the print-cartridge door.
  2. Using a flatblade screwdriver, lift up the transfer roller on the left side of the printer and slide it to the left to remove it.
    1. Transfer roller
    Do not touch the rubber sponge on the transfer roller.
  3. Install the replacement transfer roller. Make sure you install the transfer roller on the right side of the printer and then snap it into the left side of the printer.
  4. Close the print-cartridge door.
Parts return
