Feature
Type
TN Thin-Film Transistor LCD active matrix - CCFL
Viewable image area
(diagonal)
63.5 cm (25.0 in) widescreen; diagonally measured
Screen opening
(W x H)
55.30 x 31.10 cm (21.77 x 12.24 in)
Aspect ratio
16:9
Viewing angle (typical)
Up to 160° horizontal/160° vertical (10:1 minimum contrast ratio)
Brightness (typical)1
300 cd/m2 (nits)
Contrast ratio (typical)1
1000:1
Dynamic contrast ratio (typical)1
60,000:1
Response rime (typical)1
Pixel pitch1
0.288 mm
Backlight lamp life
(to half brightness)1
40,000 hours
Color gamut (typical)1
72%
note: |
- ${title}
- ${title}
- ${title}
- ${title}
HP 2509p 25-inch Premium LCD Monitor - Specifications
Panel
On Screen Display (OSD) controls
Feature
Buttons or switches
Capacitive touch controls:
Languages
User controls
Physical specifications
Feature
Dimensions (W x D x H)
Unpacked w/stand:
61.76 x 23.5 x 40.0 to 51.5 cm
(24.31 x 9.25 x 15.76 to 20.28 in)
Unpacked w/o stand (head only):
61.76 X 7.96 x 38.94 cm
(24.31 x 3.1 x 15.3 in)
Packaged:
69.7 x 22.6 x 52.5 cm
(24.29 x 8.90 x 20.67 in)
Unpacked:
9.6 kg (21.16 lb)
Head only:
6.8 kg (14.96 lb)
Packaged:
12,6 kg (27.78 lb) EPS cushion
Tilt
Yes, -5° to +25°
Swivel
Yes, range +360°/-360°
Height adjustable
Pivot rotation
Base
Signal interface/performance
Feature
Horizontal frequency
24 to 94 kHz
Vertical frequency
50 to 76 Hz
Native resolution
1920 x 1080 @ 60 Hz
Preset VESA graphic modes (non-interlaced)
Text mode
720 x 400 @ 70 Hz
Maximum pixel clock speed
200 MHz
User programmable modes
Yes (10)
Anti-Glare
No
BrightView
Yes
Default color temperature
6500K
Video/Audio and other inputs
Feature
Plug and Play
Yes
Input connectors
Video cable
Video/Other cable lengths
1.8 m (5.9 ft) ea
Yes, 2 megapixels/1 mic
Audio
2 W/Channel with power sound
Power specifications
Feature
Input power
Average power consumption
44.6 W
Maximum power consumption
65 W
Energy star power (On)
32 W or less
Power saving
<2 W in sleep mode
Power cable length
1.9 m (6.2 ft)
Environmental specifications
Feature
Temperature - operating
5° to 35°C (41° to 95°F)
Temperature - non-operating
-20° to 60°C (-4° to 140°F)
Humidity - operating
20% to 80% non-condensing
Humidity - non-operating
Altitude - operating
0 to 5000 m (16,404 ft)
Altitude - non-operating
0 to 12192 m (0 to 40,000 ft)
White LED backlights
No
CCFL panel
Yes, CCFL (4 lamp panel)
Arsenic-free glass1
No
BFR/PVC free
No
Mercury free
No
note: |
Link to product overview page
Additional support options
- ${title}
- ${title}
- ${title}
Country/Region:
Serbia
- ${title}
hp-hero-support-search
- ${title}
