    Fix Windows 10 Update Issues
HP Officejet Pro 8000 Enterprise Printer Series - Understand the Configuration Page
Use the Configuration page to view current printer information and ink cartridge status. Also use the Configuration page to help you troubleshoot problems with the printer.
The Configuration page also contains a log of recent events.
If you need to call HP, it is often useful to print the Configuration page before calling.
  1. Printer Information: Shows printer information (such as the printer name, model number, serial number, and firmware version number), the accessories that are installed (such as the duplexer), and the number of pages printed from the trays and accessories.
  2. Ink Cartridge Status: Shows the estimated ink levels (represented in graphical form as gauges) and the part numbers and expiration dates of the ink cartridges.
    Ink level warnings and indicators provide estimates for planning purposes only. When you receive a low-ink warning message, consider having a replacement cartridge available to avoid possible printing delays. You do not need to replace cartridges until prompted to do so.
  3. Printhead Status: Shows the status of the printhead health and the part numbers, first-installation dates, and end-of-warranty dates of the printheads, as well as the accumulated ink usage. The status options for the printhead are: good, fair, and replace. If the status is “fair,” then the print quality must be monitored, but the printhead does not need to replaced. If the status is “replace,” then the printhead must be replaced.
To print the Configuration page
  • Control panel: Press the OK button, select Information and then press the OK button. Press the right arrow to select Print Configuration Page and then press the OK button.
    For models that are connected to a network, the network configuration page will also be printed.
  • HP Utility (Mac OS X): Click Device Information from the Information and Support panel, and then click Print Configuration Page.
  • Embedded Web Server: Click Tools, click Printer Information in the left panel, and then click Print Self Test Page.
