HP 2509p 25-inch Premium LCD Monitor - Overview
Product description
The HP 2509p's 25-inch diagonal 16:9 display has a full HD screen with HP BrightView Technology, a 60,000:1 DCR, and a super-fast 3 ms GTG, 5 ms typical response time. It has An integrated microphone, 2MP webcam with tilt adjustability, lighted touch-activated controls and a built-in 2 port USB hub.
Product features
Feature
Panel type
TN Thin-Film Transistor LCD active matrix - CCFL
63.5 cm (25.0 in) widescreen; diagonally measured
Screen opening (w x h)
55.30 x 31.10 cm (21.77 x 12.24 in)
Aspect ratio
16:9
Viewing angle (typical)
Up to 160° horizontal/160° vertical (10:1 minimum contrast ratio)
Brightness (typical)1
300 nits (cd/m2)
Contrast ratio (typical)1
1000:1
Dynamic contrast ratio (typical)1
60,000:1
Response time (typical)1
  • 3 ms (GTG)
  • 5 ms (on/off)
Pixel pitch
0.288 mm
Backlight lamp life (to half brightness)1
40,000 hrs
Color gamut (typical)
72%
Plug and Play
Yes
Input connectors
  • VGA (analog)
  • DVI-D and HDMI w/ HDCP
  • Audio
  • USB (3 ports)
Yes, 2 megapixels/1 mic
Speakers
2 W/Channel with Power Sound
Input power
  • 100 - 240 V ac
  • 50 or 60 Hz
Average power consumption
44.6 W
Maximum power consumption
65 W
Energy Star power (On)
32 W or less
Power saving
<2 W in sleep mode
Pivot rotation
  • Limited; for rear cable access only
  • 45 degrees
