HP Color LaserJet 4700 - Replace the HP Jetdirect Print Server Card
To view a video demonstrating the procedure for removing the part click here to access the Services Media Library (www.hp.com/go/sml). Select Printers and Multifunction under the Product category, Select HP Color LaserJet Printers under the Product family, and then select the printer model under the product series category.
HP Jetdirect print server card replacement
  1. Turn the printer off.
  2. Disconnect all power and interface cables.
  3. Locate the formatter board in the rear of the printer.
  4. Loosen the retaining screws at the top and bottom of the HP Jetdirect print server card.
  5. Remove the print server card from its slot in the formatter board.
  6. Firmly insert the new HP Jetdirect print server card into the EIO slot.
  7. Insert and tighten the retaining screws that came with the print server card.
  8. Reconnect the network cable and power cable, and turn the printer on.
  9. Print a configuration page. In addition to a printer configuration page, an HP Jetdirect configuration page that contains network configuration and status information should also print.
    If the printer does not print, uninstall and reinstall the print server card to ensure that it is completely seated in the slot.
  10. Perform one of these steps:
    • Choose the correct port. See the computer or operating system documentation for instructions.
    • Run the printer installation software again, choosing the network installation this time.
Parts return
