    Fix Windows 10 Update Issues
HP Color LaserJet CM2320 Multifunction Series Printer - Replace the Cassettes
To view a video demonstrating the procedure for removing the part click here to access the Services Media Library (www.hp.com/go/sml). Select Printers and Multifunction under the Product category, select HP Color LaserJet Printers under the Product family, and then select the printer model under the product series category.
Cassette replacement
Tray 2 and optional tray 3 hold up to 250 pages of 75 g/m2 (20 lb) paper, or fewer pages of heavier media (25 mm (0.9 in) or less stack height). Load media with the top forward and the side to be printed on facing up.
  1. Pull the tray out of the product.
  2. Remove the new cassette from the package. Place the used cassette in the package for recycling. See the enclosed recycling guide for recycling instructions.
  3. Remove all orange packing material from the tray.
  4. Slide open the paper length and width guides.
    • To load Legal-size paper, extend the tray by pressing and holding the extension tab while pulling the front of the tray toward you.
      When it is loaded with Legal-size paper, the tray extends from the front of the product approximately 64 mm (2.5 inches).
  5. Place the paper in the tray and make sure that it is flat at all four corners. Slide the paper length and width guides so that they are against the stack of paper.
  6. Push down on the paper to make sure that the paper stack is below the paper limit tabs on the side of the tray.
  7. Slide the tray into the product.
Parts return
