    Fix Windows 10 Update Issues
HP Color LaserJet CM2320 Multifunction Series Printer - Replace the ADF Roller Kit
To view a video demonstrating the procedure for removing the part click here to access the Services Media Library (www.hp.com/go/sml). Select Printers and Multifunction under the Product category, select HP Color LaserJet Printers under the Product family, and then select the printer model under the product series category.
ADF pickup roller assembly removal
  1. Open the ADF cover.
  2. Disconnect one spring (callout 1).
  3. Lift up on the end of the assembly, and then slide it toward the control panel to remove it.
Tray 1 paper-pickup roller removal
The roller must be rotated into the service position to remove it.
Avoid touching the spongy roller surface unless you are going to replace the roller. Skin oils on the roller can cause paper pickup problems.
  1. Turn the product on, and wait for it to reach the Ready state. Perform the following steps to rotate the roller to the service position.
    If you have removed Tray 2 to service the product, reinstall the tray before turning the power on.
    The following steps rotate the engine paper-pickup roller and the Tray 1 paper-pickup roller into the service position.
    1. Open the 2ndry Service menu by pressing the Left Arrow button and the Cancel button simultaneously.
    2. Use the arrow buttons to select Pick roller, and then press OK.
      Press OK again to confirm that you want the roller to rotate.
    3. Listen for the roller to rotate. When the roller is done rotating, unplug the power cord and then place the power switch in the off position.
      Failure to unplug the product at this point will result in the roller being in the incorrect position for the repair procedure.
      It is important to place the power switch in the off position after unplugging the power cord so that the product power does not come on immediately when the power cord is plugged in again.
    4. Remove Tray 2.
    5. Perform the remaining steps in this procedure to remove the roller. After replacing the roller, plug the power cord into the product, and then use the power switch to turn the power on.
  2. Lower the Tray 1 paper pickup assembly by pushing down on the edges of the assembly.
  3. Carefully raise the front of the product.
      warning:
    Do not place the product face-up resting on the rear cover and rear door. Excess toner might enter the laser/scanner assembly and contaminate the mirrors, causing print-quality problems. The laser/scanner is not a FRU. If the laser/scanner mirrors are contaminated, the entire product must be replaced.
    Do not lift the product grasping the front door and Tray 2 cavity.
  4. Release two tabs, and then rotate the roller away from the product to remove it.
Tray 1 separation pad removal
Avoid touching the pad surface unless you are going to replace the pad. Skin oils on the pad can cause paper pickup problems.
  1. Remove Tray 2 (if installed).
  3. Release the retainer tabs, and then remove the separation pad from the base.
    The separation pad base can easily be dislodged when the pad is removed. If the base is dislodged, do not loose the spring under the base (it is not captive).
Parts return
