HP Color LaserJet CP6015 Series Printer - Replace the Fuser
To view a video demonstrating the procedure for removing the part click here to access the Services Media Library (www.hp.com/go/sml). Select Printers and Multifunction under the Product category, Select HP Color LaserJet Printers under the Product family, and then select the printer model under the product series category.
Fuser replacement
  1. Turn the power off.
  2. Open the right door.
  3. Pull the two blue fuser handles forward.
    The fuser can be hot while the product is in use. Wait for the fuser to cool before handling it.
  4. Rotate the fuser-release levers down to open them.
  5. Grasp the fuser handles and pull straight out to remove the fuser. Recycle the used fuser following the instructions included with the new fuser.
    The fuser weighs 5 kg (11 lbs). Be careful not to drop it.
  6. Remove the new fuser from its protective bag. Make sure the fuser-release levers are in the down and open position. Align the fuser with the arrows on the product. Push the fuser completely into the printer.
  7. Rotate the fuser-release levers up to lock the fuser into place.
  8. Push the fuser handles back to close them.
  9. Close the right door and turn the power on.
Parts return
