HP Compaq LA2306x 23-inch WLED Backlit LCD Monitor - Option Parts
New model specific parts lists
To look up RoHS-compliant information in PartSurfer, use the component’s option part number or the sales order number for a system in which the component is used (available from the product QuickSpecs). Click here to visit the HP PartSurfer website.
Options
Feature
Option Part Number
HP Single Monitor Arm
BT861AA
HP Adjustable Dual Display stand
AW664AA
HP LCD Speaker bar
NQ576AA
HP LCD Monitor Quick Release1
EM870AA
HP Integrated Work Center stand
GN783AA
HP USB Graphics adapter
NL571AA
HP Business PC security lock kit
PV606AA
HP DisplayPort cable kit
VN567AA
1: The HP Quick Release has been designed to support a maximum of up to 10.9 kg (24 lbs) for all devices mounted. Because mounting surfaces vary widely and the final mounting method and configuration may vary, mounting fasteners are not supplied (other than the VESA-compliant screws). HP recommends that you consult with a qualified engineering, architectural or construction professional to determine the appropriate type and quantity of mounting fasteners required for your application and to ensure that your mounting solution is properly installed to support applied loads.
