HP Compaq LE1901wl 19-inch WLED Backlit Monitor - Specifications
On Screen Display (OSD) control specifications
Feature
Buttons or switches
  • OSD Menu
  • OSD Minus (-)
  • OSD Plus (+)
  • Auto adjust/OK
  • Power
Language
  • English
  • Spanish
  • French
  • German
  • Dutch
  • Italian
  • Japanese
  • Simplified Chinese
  • Traditional Chinese
  • Portuguese
User controls
  • Brightness
  • Contrast Brightness
  • Contrast
  • Positioning
  • Color temperature
    • 6500k
    • 9300k
    • Custom
  • Image Control
    • Clock
    • Clock Phase
    • Position
    • Custom Scaling
  • OSD Control
  • Management
  • Language
  • Factory reset
Panel specifications
Feature
Type
Twisted Nematic (TN) WLED Backlit LCD
47 cm (18.5 in) widescreen
Screen opening (W x H)
40.9 x 23 cm (16.1 x 9.05 in)
Viewing angle (typical)
Up to 170° horizontal/160° vertical (10:1 minimum contrast ratio)
Aspect ratio
16:9
Brightness (typical)1
250 nits (cd/m2)
Contrast ratio (typical)1
1000:1
Dynamic contrast ratio
N/A
Response time (typical)1
5 ms (on/off)
Pixel pitch
0.03 cm
Backlight lamp life (to half brightness)
30,000 hours
Color gamut
68%
1: All performance specifications represent the typical specifications provided by HP's component manufacturers; actual performance may vary either higher or lower.
Signal interface/performance specifications
Feature
Horizontal frequency
24 to 83 kHz
Vertical frequency
48 to 76 Hz
Native resolution
  • 1366 x 768 @ 60 Hz
  • 1280 x 1024 @ 60 Hz
  • 1280 x 960 @ 60 Hz
  • 1280 x 720 @ 60 Hz
  • 1024 x 768 @ 60 Hz
  • 800 x 600 @ 60 Hz
  • 720 x 400 @ 70 Hz
  • 640 x 480 @ 60 Hz
Text mode
720 x 400 @ 70 Hz
Mac mode
1152 x 864 @ 75 Hz and 832 x 624 @ 75 Hz
Maximum pixel clock speed
140 MHz
User programmable modes
10
Anti-glare
Yes
Anti-static
Yes
Default color temperature
6500 K
Video/Other inputs specifications
Feature
Plug and play
Yes
Input signal
VGA, VGA cable included
Input impedance
75 ohms ± 2%
Sync input
TTL separate synch or composite synch
Video cables
15 pin D-sub VGA
VGA cable length
1.8 m (5.9 ft)
Power specifications
Feature
Input power
Auto-Sensing, 100 to 240 V ac, 50/60 Hz
Frequency
47 Hz to 63 Hz
Typical power consumption
20 W
Maximum
22.8 W
Power saving
< 2 W sleep
Power cable length
1.8 m (5.9 ft)
Physical specifications
Feature
Dimensions (H x W x D)
Unpacked w/stand: 34.1 x 44.6 x 19.0 cm (13.4 x 17.6 x 7.5 in)
Unpacked w/o stand (head only): 26.9 x 44.6 x 5.8 cm (10.6 x 17.6 x 2.3 in)
Packaged: 42.0 x 51.3 x 14.0 cm (16.5 x 20.2 x 5.5 in)
Unpacked: 3.3 kg (7.3 lb)
Packaged: 4.5 kg (9.9 lb)
Ergonomic features specifications
Feature
Tilt range
-5° to + 25° vertical
Swivel range
None
Height adjustable
No
Pivot rotation
No
Base
Detachable, ships detached
Environmental specifications
Feature
Temperature
Operating: 5° to 35°C (41° to 95°F)
Non-operating: -20° to 60°C (-4° to 140°F)
Humidity
Operating: 20% to 80% non-condensing
Non-operating: 5% to 95%, 38.7°C (101.66°F)max wet-bulb
Altitude
Operating: +0 to 5,000 m (16,404 ft)
Non-operating: +0 to 12,192 m (40,000 ft)
White LED backlights
Yes
CCFL panel
No
Arsenic-Free glass (100% free)
Yes
BFR/PVC free
No
Mercury free
Yes
Other accessories and software specification
Feature
Accessories included
VGA cable, Power cord
HP Display Assistant - a software utility that allows monitor adjustment and color calibration using the Display Data Channel Command Interface (DDC/CI) protocol of the connected PC.
User guide languages
  • English
  • Spanish
  • Korean
  • Japanese
  • Spanish
  • Portuguese
Color
Black
VESA external mounting
Yes, standard 4 hole pattern, 100 mm
Certificates and compatibility specification
Feature
Certification and compliance
  • TCO 5.0 displays
  • ISO 9241-307
  • CISPR requirements
  • VCCI approvals
  • KC and KCC (Korean) requirements
  • CSA 60950-1
  • UL 60950-1
  • EN55022 class B
  • CNS 13438 class B
  • IEC 60950-1
  • China Energy Label (CEL)
  • China MEPS
  • Korea MEPS (pending, energy boy)
  • SmartWay - NA only - energy logistics
  • EUP Lot 6 Tier 1 AS/NZS 3548 class B approval
  • GS Mark
  • TUV approvals
  • GEEA
  • CE marking
  • FCC part 15 class B approval
  • ENERGY STAR qualified
  • EN55024 class B
  • EN60950 -1
  • CUL
  • CCIB
  • CCEE
  • IT ECO (EDS)
  • EPEAT silver1
Compatibility
Recommended for use with HP products.
1: EPEAT Silver where HP registers commercial display products. See www.epeat.net for registration status in your country.
