    Coronavirus (COVID-19) Impact
    We are experiencing longer than expected wait times to reach an agent. Please use the resources here on our HP Support website to answer your questions and troubleshoot any issues you may be experiencing.  Try our Virtual Agent and Diagnostic Tools for faster service.
    Microsoft Support for Windows 7 ended on Jan 14, 2020
    HP recommends that you begin the process of upgrading to Windows 10 if your computer has been tested by HP. For more information, click here.
HP Printers - Printing with Apple AirPrint (iOS)
This document is for HP AirPrint-compatible printers and the Apple iPhone, iPad and iPod touch.
AirPrint is a built-in printing solution for Apple computers and mobile devices. You can print from most apps that have a print feature.
On iOS and macOS, most HP printers work with Apple AirPrint to provide full-quality printing without the need to download or install drivers. For additional functionality, please download the HP Smart app from the App Store for iPhone and iPad or the Mac App Store.
Step 1: Set up the network connection
Wirelessly connect the printer and the Apple device to use AirPrint.
  1. On your Apple device, make sure Wi-Fi is on and there is a check mark next to the name of your local Wi-Fi network. If you are connected to a different network, tap the name of your network to join it.
    Go to Finding Your Wireless Password if you do not know the network login information.
    If a local network is unavailable or you use a USB cable to connect the printer to a computer, go to How do I use AirPrint if a Wi-Fi network is not available? for steps to use the Wi-Fi Direct or HP wireless direct printer connection.
  2. Check the printer network connection status.
    • Printers with a touchscreen control panel: Touch the Wireless icon or open the Network Settings or Setup menu to view the network connection status.
    • Printers without a touchscreen control panel: Press the Wireless and Information buttons at the same time or press the Wireless and Start Copy Black buttons at the same time. A Wireless Test Report prints with the network connection status.
  3. Do the following, depending on the connection status.
    • If the printer is connected to the network, skip to the step to print from your device.
    • If the printer is not connected to the network, continue to the next step.
  4. Connect the printer to the network.
    • Printers with a touchscreen control panel: On the printer, open the Setup, Network, or Wireless menu, select Wireless Setup Wizard, and then follow the instructions to connect the printer to your network.
    • Printers without a touchscreen control panel: Press and hold the Wireless and Cancel buttons at the same time until the Power light flashes, and then wait for the Wireless light to flash. For Tango printers, press and hold the Wireless button on the rear of the printer for five seconds until the Edge lighting flashes blue.
      Within two hours, press and hold the WPS button (Wi-Fi Protected Setup) on the router until the connection process begins. The Wireless light on the printer stops flashing when the connection completes.
Step 2: Print from your Apple device
Print documents, photos, and webpages using AirPrint.
  1. Make sure the printer is turned on, ink cartridges are installed, and plain paper is loaded in the main tray.
  2. Open the item you want to print, and then tap the Share icon or .
  3. Tap Print or the Print icon to open Printer Options.
  4. Tap Select Printer to select your printer.
  5. Change any of the following print job settings. Available settings vary depending on the app you are printing from, the print job type, and your printer.
    • Paper: Make any paper size changes on the printer. AirPrint automatically detects the paper size loaded in the printer or the size selected on the printer control panel. If the detected size is different than the paper in the tray, an error might display asking to confirm the size.
    • Number of copies: Select how many copies you want to print.
    • Black & White: Select to print in grayscale. This option only displays for color printers.
    • Double-sided printing: Print on both sides of the paper for certain file types.
    • Page range: Select specific pages within a document or webpage to print.
    Printer Options screen
Review the list of frequently asked questions about printing with AirPrint.
