    Fix HP Printer issue on macOS
HP Designjet T2300 eMFP - Overview
Product description
  • HP Designjet T2300 eMultifunction Printer - CN727A
  • HP Designjet T2300 PostScript eMultifunction Printer - CN728A
The HP Designjet T2300 eMFP is the first ever Web ready printing system with MFP benefits. With HP ePrint & Share, you can preview, create a pdf at the same time, print, access and share files easily, cost effectively, and reliably. This printer can automatically create a print ready PDF and upload it to your personal Web library, the instant you hit print.
This printer can scan sketches and hand annotated drawings. Also can work on multiple projects at the same time with two rolls and smart switching. The product can be controlled from its front panel or from a remote computer using the Embedded Web Server or the HP Utility. The front panel is in color which is touch sensitive with an intuitive graphical user interface.
Product features
Feature
Print:
Technology
HP Thermal Inkjet
Ink cartridge colors
  • Cyan
  • Gray
  • Magenta
  • Matte black
  • Photo black
  • Yellow
Ink types
  • Dye based (C, M, Y, G, pK)
  • Pigment based (mK)
Ink drop
  • 6 pl (C, M, pK, G)
  • 9 pl (Y, mK)
Ink cartridge size
  • 300 ml (matte black)
  • 130 ml (cyan, gray, magenta, matte black, photo black, yellow)
  • 69 ml (cyan, gray, magenta, photo black, yellow)
Line accuracy
+/- 0.1%
Line drawings
Fast: 28 sec/page on A1/D, 103 A1/D prints per hour
Color image
  • Fast : 41 m²/hr (445 ft²/hr)
  • Best: 3.1 m²/hr (33.3 ft²/hr)
Print resolution
Up to 2400 x 1200 optimized dpi from 1200 x 1200 input dpi and Optimization For Photo Paper selected
Scan
Scan speed
  • Color: 3.81 cm/sec (1.5 in/sec)
  • Grayscale: 11.43 cm/sec (4.5 in/sec)
Scan/copy resolution
Up to 600 dpi
Maximum scan size
91.4 x 237.8 cm (36 x 93.6 in)
Maximum scan thickness
0.8 mm (0.03 in)
Copy
Reduction/enlargement
25 to 400%
Maximum copies
Up to 99 copies
Copier settings
  • Copy quality
  • Copy color
  • Roll
  • Content type
  • Original paper type
  • Background removal
  • Contrast
  • De-skew
Others:
Memory
  • 32GB (virtual)
  • 160GB hard disk
Interfaces (standard)
  • Gigabit Ethernet (1000Base-T)
  • Hi-Speed USB 2.0 certified
  • EIO Jetdirect accessory slot
Print languages (standard)
  • eMFP: TIFF, JPEG , HP-GL/2, HP-RTL, CALS G4, HP PCL 3 GUI
  • PostScript eMFP: Adobe PostScript 3 , Adobe PDF 1.7, TIFF, JPEG, HP-GL/2, HP-RTL, CALS G4, HP PCL 3 GUI
1 year limited hardware warranty
Software overview
Feature
Printer software
  • HP-GL/2 and HP RTL driver for Windows
  • PCL3GUI raster driver for Mac OS (T2300)
  • PostScript drivers for Windows and Mac OS (T2300 PS)
  • Embedded Web Server
