HP and Compaq Desktop PCs - Motherboard Specifications, ZN2 (Matadi)
Figure : The ZN2 (Matadi) motherboard
 Photograph of motherboard
Form Factor
  • Custom 272 mm (10.7 inches) x 245 mm (9.6 inches)
  • Intel A57 Express
Front-side bus speed
  • DMI (Direct Media Interface)
    Speed measurement for DMI is not applicable.
Upgrade Information
Integrated video
Integrated audio
Integrated network
I/O Ports and internal connectors
Jumper settings
Do not change any jumper setting while the computer is on. Damage to the motherboard can result.
Motherboard layout
Figure : layout
Photograph of motherboard layout
