    We are upgrading our website
    If you experience errors during this time, please try again later. Sorry for the inconvenience.
    Find Windows 11 and Windows 10 support help. Visit Windows Support Center
     Connect with HP support faster, manage all of your devices in one place, view warranty information and more. Sign up for an HP account
HP and Compaq Desktop PCs - Motherboard Specifications, MS-7613 (Inverness)
Figure : The MS-7613 (Inverness) motherboard
 Photograph of motherboard
Form Factor
  • Micro-ATX 24.4cm (9.6 inches) x 24.4cm (9.6 inches)
  • Intel H57 PCH
Front-side bus speed
  • DMI (Direct Media Interface)
Unlike for Front Side Bus, System Bus, and Intel QPI, the speed measurement for DMI is not applicable.
Upgrade Information
Integrated video
Integrated audio
Integrated network
I/O Ports and internal connectors
Jumper settings
Do not change any jumper setting while the computer is on. Damage to the motherboard can result.
Motherboard layout
Figure : layout
Line drawing of motherboard showing components
