    Apache Log4j Update
HP Designjet T2300 eMFP Product Series - Check usage statistics
There are various ways of checking your product's usage statistics.
The accuracy of the usage statistics is not guaranteed.
From the Embedded Web Server
  1. Access the Embedded Web Server, see Access the Embedded Web ServerAccess the Embedded Web Server.
  2. Go to the Main tab.
  3. Select History > Usage.
From the HP Utility
  1. Access the HP Utility, see Access the HP UtilityAccess the HP Utility.
  2. Under Windows, go to the Overview tab and click on the Printer usage link.
    Under Mac OS, select Information > Printer Usage and click on the Lookup button.
From the front panel
  1. Press .
  2. Press .
  3. Press Internal prints.
  4. Press User information prints.
  5. Press Print usage report.
