    Apache Log4j Update
HP Designjet T2300 eMFP Product Series - Copying
Copying
Before starting to copy, see Paper types suitable for scanningPaper types suitable for scanning.
  1. Load the sheet with the printed side facing upwards (you can also load the sheet before step 1, if you prefer). Align the center of the sheet approximately with the center of the scanner. Use the standard size markings to help you.
    The scanner can scan a maximum length of 2378 mm. A longer sheet than this can be moved through the scanner, but only the first 2378 mm will be scanned. An alert is displayed if the maximum length is exceeded.
  2. Push the sheet into the insertion slot until you feel it contact the rollers. The scanner will automatically grab the sheet and move it into position for scanning. You can press to eject the sheet if you feel that it has loaded badly and you want to try again.
  3. At the front panel, go to the home screen and press .
  4. Some of the default copy settings are displayed. Press Settings to see the complete list of settings, and check in particular that the Paper type setting corresponds to the paper type that you intend to scan.
    • Size allows you to resize the print in two different ways: to a percentage of its original size, or to fit a particular paper size. The default is 100% (its original size).
    • Copy quality allows you to set the print quality to Best, Normal or Fast.
    • Copy color allows you to choose color or grayscale printing.
    • Roll allows you to specify printing on roll 1 or roll 2, or you can choose Save paper, which automatically chooses the narrowest roll on which the print will fit.
    • Content type allows you to optimize the scan for a line drawing, a photographic image, or a mixed image.
    • Original type allows you to specify the paper type on which the original image has been printed. To optimize scan quality, ensure that this setting is correct.
    If you change the settings in this way, the changed settings apply to the current job but are not saved permanently. You can change the default settings from the main menu: press , then , then Copy preferences.
  5. When you are satisfied with the copy settings, press anywhere on the screen to return to the previous page, then press Start.
  6. If two rolls are loaded, you can choose to print on either roll, or you can let the printer choose automatically.
    The printer will automatically rotate the image by 90° if it can save paper by doing so.
  7. When the scan is complete, press to eject the scanned sheet from the scanner; be ready to pick it up.
  8. While the scanned image is being printed, you can perform some other operation: you don't need to wait for the end of the print.
  9. After printing, you can choose to make another copy or go to the job queue. If you make another copy immediately without returning to the home screen, the temporary settings used for the previous copy are used again.
By default, if the original is skewed in the scanner (not loaded straight), the scanner will try to correct the skew automatically. To turn off this automatic correction, press , then , then Scan preferences > De-skew > Off.
