HP LaserJet Pro CP1025 Printers - Blinking Lights
This document is for HP LaserJet Pro CP1025 and CP1025nw Color printers.
The lights on the front of the printer indicate the printer status. These lights can be on, off, or blinking (flashing), depending on the status of the printer. Blinking lights can indicate error conditions. They might also indicate that the printer is starting up, processing a print job, or charging batteries.
The following sections describe the most common issues related to the light patterns on your product. Find the issue related to the blinking lights pattern you are experiencing, and then follow the steps to resolve the issue.
There might be more than one solution for some blinking lights patterns. After you find the pattern that matches your blinking lights pattern, try each solution to resolve the issue.
Blinking lights
The following sections describe the most common combinations of blinking lights, followed by solutions for each combination. Find the blinking lights pattern you are experiencing, and then follow the steps to resolve the issue.
Issue: All lights off
Image: All lights off.
Issue: Attention and Ready lights cycling
Image: Attention and Ready lights cycling.
Issue: Ready light on
Image: Ready light on.
Issue: Ready light blinking
Image: Ready light blinking.
Issue: Attention light blinking and Ready light on
Image:
Image: Attention light blinking.
Issue: Attention and Ready lights on
Image: Attention and Ready lights  on.
Issue: Attention light and Ready light blinking
Image: Attention and Ready light blinking.
Issue: Print Cartridge light blinking
Image: Print Cartridge light blinking.
Issue: Print Cartridge and Attention lights blinking
Image: Print Cartridge and Attention lights blinking.
Issue: Print Cartridge and Ready lights on
Image: Cartridge and Ready lights on.
Issue: The wireless light is on (CP1025nw model only)
Image: The wireless light is on.
Issue: Wireless light off (CP1025nw model only)
Image: Wireless light off.
Issue: Wireless light blinking (CP1025nw model only)
Image: Wireless light blinking.
