HP 620 Notebook PC - Removing and Replacing the Pick Button Board
This document is provided to assist in removing and replacing the pick button board for the HP 620 Notebook PC.
Minimum skill level
The End-user should possess product-specific knowledge and technical skill on how to service the system, and have familiarity with the operating system.
Tools required
Small, Phillips-head (P1) screwdrivers.
Parts required
The replacement part number will vary depending on the pick button board that is being replaced. If a part is listed as "Yes" under "Requires return" then the defective part needs to be returned to HP.
Part number
Requires return
TouchPad board
605795-001 (Modified)
No
Summary of instructions
To view a video demonstrating the procedure for removing the pick button board, click on the link below. Or use the product video listing on the HP Services Media Library (Click here to go to HP Service Media Library), then select Pick button board from the menu on the upper left hand side of the screen.
Click here to view the pick button board removal video (right-click on the link to open in a new window/tab).
Pick button board removal
  2. On the bottom of the palm rest, use minimal force to lift the locking bar up on the pick button board ZIF connector and disconnect the pick button board ribbon cable from the TouchPad board.
    Use care to prevent damaging the ZIF connector and ribbon cable.
  3. Remove the 3 mm P1 Phillips-head screw that secures the pick button board to the palm rest.
  4. Lift the pick button board off of its alignment pins and slide the pick button board out from underneath the tabs on the palm rest.
  5. Remove the pick button board and place it in a static dissipative bag.
Pick button board replacement
  1. Remove the pick button board from the static dissipative bag.
  2. Toe the pick button board underneath the tabs on palm rest and lower the pick button board onto its alignment pins.
  3. Replace the 3 mm P1 Phillips-head screw that secures the pick button board to the palm rest.
  4. Insert the pick button board ribbon cable into the pick button board ZIF connector on the TouchPad board.
  5. Press the locking bar down to lock the pick button board ribbon cable in the pick button board ZIF connector on the TouchPad board.
Country: Flag Serbia
