HP 620 Notebook PC - Removing and Replacing the Memory Module
This document is provided to assist in removing and replacing the memory module for the HP 620 notebook PC.
Minimum skill level
The End user requires no hardware-specific training to replace the defective part. The End user should have familiarity with system hardware and software requiring repair.
Tools required
Small, flat-bladed screwdriver or a flat-bladed alignment tool.
Parts required
The replacement part number will vary depending on the memory module that is being replaced. If a part is listed as "Yes" under "Requires return" then the defective part needs to be returned to HP. Click here for more information on returning parts to HP.
Part number
Requires return
2GB, PC3-10600, shared DDR3-1333 MHz SDRAM Small Outline Dual In-Line Memory Module (SODIMM)
598856-001 (Modified)
Yes
1GB, PC3-10600, shared DDR3-1333 MHz SDRAM Small Outline Dual In-Line Memory Module (SODIMM)
598859-001 (Modified)
Yes
Summary of instructions
To view a video demonstrating the procedure for removing the memory module, click on the link below. Or use the product video listing on the HP Services Media Library (Click here to go to HP Service Media Library), then select Memory module from the menu on the upper left hand side of the screen.
Click here to view the memory module removal video (right-click on the link to open in a new window/tab).
Memory module removal
  2. Push both arms outward simultaneously to release the memory module to the spring tension position.
    The primary and expansion memory slots are both located under the bottom door. The primary memory slot is located on the bottom and the expansion memory slot is located on top. If an expansion memory module is installed, it must be removed before the primary memory module can be removed.
  3. Grasp the memory module by the edges and pull gently to remove it.
    When handling a memory board, use care to prevent touching the memory chips on the module. Touching the memory chips could damage or destroy the memory.
  4. Place the memory module in a static dissipative bag.
Memory module replacement
  1. Grasp the memory module by its edges and remove the memory module from the static dissipative bag.
  2. Locate the alignment notch on the memory module and align it with the memory module connector on the system board.
  3. Gently push the memory module into the memory module connector until it is secure.
  4. Push the exposed edge of the memory module down until you hear the click of the two retention arms.
Country: Flag Serbia
