    Fix Windows 10 Update Issues
HP ProBook 6450b Notebook PC - Removing and Replacing the RTC Battery
This document is provided to assist in removing and replacing the RTC battery for the HP ProBook 6450b Notebook PC.
Minimum skill level
Tools required
Small, Phillips-head (P1) screwdriver.
Parts required
The replacement part number will vary depending on the RTC battery that is being replaced. If a part is listed as "Yes" under "Requires Return" then the defective part needs to be returned to HP.
Part Number
Requires Return
RTC battery - 3 V dc, 250 mAh, lithium coin cell battery - Type CR2330 or equivalent - Not rechargeable
449137-001 (Modified)
No
Summary of instructions
To view a video demonstrating the procedure for removing the RTC battery, click on the link below. Or use the product video listing on the HP Services Media Library (Click here to go to HP Services Media Library), then select RTC battery from the menu on the upper left hand side of the screen.
Click here to view the RTC battery removal video (right-click on the link to open in a new window/tab).
RTC battery removal
  2. note:
    The video shown depicts a different model of the notebook. The same removal and replacement procedures apply to this notebook.
  3. Using a non metallic flat bladed tool, gently push the RTC battery to the right until the left edge of the RTC battery is free from its socket.
  4. Remove the RTC battery.
RTC battery replacement
  1. With the positive side of the RTC battery facing up, toe the right edge of the RTC battery into its socket and gently press down until it snaps into place.
