HP ProBook 5320m Notebook PC - Removing and Replacing Memory Module
This document is provided to assist in removing and replacing the memory module for the HP ProBook 5320m notebook PC.
Minimum skill level
Tools required
Small, Phillips-head (P1) screwdrivers.
Parts required
The replacement part number will vary depending on the memory module that is being replaced. If a part is listed as "Yes" under "Requires Return" then the defective part needs to be returned to HP. Click here for more information on returning parts to HP.
Part Number
Requires Return
4GB, PC3-10600, shared DDR3-1333MHz SDRAM Small Outline Dual In-Line Memory Module (SODIMM)
599092-001 (Modified)
Yes
2GB, 1333MHz, 240-pin, PC3-10600 DDR3-1333 SDRAM Small Outline Dual In-Line Memory Module (SODIMM)
581096-001 (Modified)
Yes
1GB, PC3-10600, shared DDR3-1333MHz SDRAM Small Outline Dual In-Line Memory Module (SODIMM)
598859-001 (Modified)
Yes
Summary of instructions
To view a video demonstrating the procedure for removing the memory module, click on the link below. Or use the product video listing on the HP Services Media Library (Click here to go to HP Service Media Library), then select Memory Module from the menu on the upper left hand side of the screen.
Click here to view the memory module removal video (right-click on the link to open in a new window/tab).
Memory module removal
  2. Loosen the two captive P1 Phillips-head screws identified with a memory and storage drive icon that secure the accessory cover to the base enclosure.
  3. Slide the accessory cover toward the front edge of the base enclosure and remove it.
  4. Push both arms outward simultaneously to release the memory module to the spring tension position.
    When handling a memory module use care to prevent touching the memory chips on the board. Touching the memory chips could damage or destroy the memory.
  5. Grasp the memory module by the edges and pull gently to remove it.
  6. Place the memory module in a static dissipative bag.
Memory module replacement
  1. Grasp the memory module by the edges and remove it from the static dissipative bag.
  2. Align the notch in the memory module with the key in the memory module slot on the system board.
  3. At an angle, gently insert the memory module into its slot on the system board.
  4. Press the memory module down to latch the arms.
  5. Place the accessory cover into position on the base enclosure and slide the accessory cover.
  6. Tighten the two captive P1 Phillips-head screws identified with a memory and storage drive icon that secure the accessory cover to the base enclosure.
Verifying successful repair
Power on the server and verify that the BIOS memory and processor messages are displayed on the monitor during the boot process.
Parts return
