    Fix Windows 10 Update Issues
HP ProBook 6540b Notebook PC - Removing and Replacing Solid State Drive
This document is provided to assist in removing and replacing the solid state drive for the HP ProBook 6540b Notebook PC.
Minimum skill level
Tools required
Small, Phillips-head (P1) screwdrivers
Parts required
The replacement part number will vary depending on the solid state drive that is being replaced. If a part is listed as "Yes" under "Requires Return" then the defective part needs to be returned to HP. Click here for more information on returning parts to HP.
Part Number
Requires Return
128GB Solid State Drive (SSD) storage drive - SATA interface, 2.5-inch form factor - Includes bracket
583247-001 (Modified)
Yes
Hard drive SATA SSD 2.5-inch form factor
598089-001 (Modified)
Yes
Summary of instructions
To view a video demonstrating the procedure for removing the solid state drive, click on the link below. Or use the product video listing on the HP Services Media Library (Click here to go to HP Service Media Library), then select Solid state drive from the menu on the upper left hand side of the screen.
Click here to view the solid state drive removal video (right-click on the link to open in a new window/tab).
Solid state drive removal
  2. Loosen the two captive P1 Phillips-head screws that secure the solid state drive cover to the base enclosure.
  3. Lift the solid state drive cover and remove it.
  4. Loosen the captive P1 Phillips-head screw that secures the solid state drive to the base enclosure.
  5. Grasp the Mylar tab that is attached to the solid state drive bracket and slide the solid state drive away from the solid state drive connector on the system board.
  6. Remove the solid state drive from the primary storage drive bay.
  7. Place the solid state drive in a static dissipative bag.
Solid state drive replacement
  1. Remove the solid state drive from the static dissipative bag.
  2. Toe the solid state drive into the primary storage drive bay and align it with the system board connector.
  3. Press the solid state drive into the connector on the system board until it is firmly seated.
  4. Tighten the captive P1 Phillips-head screw that secures the solid state drive to the base enclosure.
  5. Toe the solid state drive cover into the base enclosure and lower it into position.
  6. Tighten the two captive P1 Phillips-head screws.
Parts return
