HP ProBook 6440b Notebook PC - Removing and Replacing Touchpad
This document is provided to assist in removing and replacing the touchpad for the HP ProBook 6440b Notebook PC.
Tools required
Small, flat-bladed screwdriver or a flat-bladed alignment tool
Parts required
The replacement part number will vary depending on the touchpad that is being replaced. If a part is listed as "Yes" under "Requires Return" then the defective part needs to be returned to HP.
Part Number
Requires Return
Touchpad 14.0
593867-001 (Modified)
No
Summary of instructions
To view a video demonstrating the procedure for removing the touchpad, click on the link below. Or use the product video listing on the HP Services Media Library (Click here to go to HP Service Media Library), then select Touchpad from the menu on the upper left hand side of the screen.
Click here to view the touchpad removal video (right-click on the link to open in a new window/tab).
Touchpad removal
  2. Using a non-metallic, flat bladed tool, gently pry the top edge of the touchpad away from the top cover.
  3. Rotate the top edge of the touchpad toward the front of the base enclosure to gain access to the touchpad ZIF connectors.
  4. Using minimal force, lift the locking bar up on the touchpad ZIF connector on the system board and disconnect the touchpad ribbon cable.
    Use care to prevent damaging the ZIF connector and ribbon cable.
  5. Using minimal force, lift the locking bar up on the touchpad button ZIF connector on the touchpad and disconnect the touchpad button ribbon cable.
  6. Remove the touchpad from the base enclosure and place it in a static dissipative bag.
Touchpad replacement
  1. Remove the touchpad from the static dissipative bag.
  2. While holding the touchpad in one hand, insert the touchpad button ribbon cable into the touchpad button ZIF connector on the touchpad.
  3. Push the locking bar down to lock the touchpad button ZIF connector.
  4. Insert the touchpad ribbon cable into the touchpad ZIF connector on the system board.
  5. Push the locking bar down to lock the touchpad ZIF connector.
  6. Place the touchpad into position on the top cover.
  7. Press along the edges of the touchpad to adhere it to the top cover.
