    Fix Windows 10 Update Issues
HP ProBook 4321s Notebook PC - Removing and Replacing Memory Module
This document is provided to assist in removing and replacing the memory module for the HP ProBook 4321s Notebook PC.
Minimum skill level
The End-User should possess product-specific knowledge and technical skill on how to service the system, and have familiarity with the operating system.
Tools required
Small, Phillips-head (P1) screwdrivers.
Parts required
The replacement part number will vary depending on the memory module that is being replaced. If a part is listed as "Yes" under "Requires Return" then the defective part needs to be returned to HP. Click here for more information on returning parts to HP.
Part Number
Requires Return
Memory module (PC3-10600, 1333-MHz, DDR3, shared)
2048MB
598856-002 (Modified)
Yes
1024MB
598859-002 (Modified)
Yes
Summary of instructions
To view a video demonstrating the procedure for removing the memory module, click on the link below. Or use the product video listing on the HP Services Media Library (Click here to go to HP Service Media Library), then select Memory module from the menu on the upper left hand side of the screen.
Click here to view the memory module removal video. (right-click on the link to open in a new window/tab).
Memory module removal
    Click here to view the precautions.
  2. Remove the three 3 mm P1 Phillips-head screws that secure the keyboard to the top cover.
  3. Remove the 4 mm P1 Phillips-head screw that secures the keyboard to the top cover.
  4. Slide the keyboard toward the rear of the notebook until the tabs on the front of the keyboard are free from their respective slots on the top cover.
  5. Flip the keyboard toward the right side of the notebook and rest it face down.
  6. Push both arms outward simultaneously to release the memory module to the spring tension position.
    The primary and expansion memory slots are both located under the keyboard. The primary memory slot is located on the bottom and the expansion memory slot is located on top. If an expansion memory module is installed, it must be removed before the primary memory module can be removed.
    When handling a memory module, use care to prevent touching the memory chips on the board. Touching the memory chips could damage or destroy the memory.
  7. Place the memory module in an electrostatic dissipative bag.
Memory module replacement
  1. Grasp the memory module by the edges and remove it from the electrostatic dissipative bag.
  2. Locate the alignment notch on the memory module and align it with the memory module connector on the system board.
  3. Gently push the memory module into the memory module connector until it is secure.
  4. Push the exposed edge of the memory module down until you hear the click of the two retention arms.
  5. Flip the keyboard toward the center of the notebook and align the tabs on the front of the keyboard with the slots on the top cover.
  6. While pressing down on the front and rear edges, slide the keyboard forward until it is securely seated under the lip of the palm rest.
  7. Replace the 4 mm P1 Phillips-head screw that secures the keyboard to the top cover
  8. Replace the three 3 mm P1 Phillips-head screws that secure the keyboard to the top cover.
Verifying successful repair
Power on the server and verify that the BIOS memory and processor messages are displayed on the monitor during the boot process.
Parts return
