    Fix HP Printer issue on macOS
HP Scanjet G4010/G4050/G3010 Scanner - Scan a Slide or Negative Using HP Solution Center version 13.0
Affected products:
HP Scanjet G3010/G3110 Photo Scanner
HP Scanjet 8300 Professional Image Scanner
HP Scanjet G4050 Photo Scanner
HP Scanjet 8270 Document Flatbed Scanner
HP Scanjet G2710/G4010 Photo Scanner
HP Scanjet 5590 Digital Flatbed Scanner series
HP Scanjet 8300 Digital Flatbed Scanner
Use the transparent materials adapter (TMA) to scan slides or negatives.
Details
Follow the steps given below:
  1. Launch HP Solution Center
  2. Click on Scan Film.
  3. Click on Slides to File, Click on Change settings (change the resolution, File type, destination etc.)
  4. Settings under Change Settings.
  5. Check the Settings under Advanced TMA settings (Change the Resolution, Remove the Dust and scratches, Sharpen, etc,)
  6. Settings under Save to File Save Options (Change the file type and destination).
  7. Preview window.
  8. Once the slides are cropped, click on Finish. Click on Done to complete the scanning
