HP ENVY 100 e-All-in-One Printer Series (D410) - Setting up the All-in-One (Hardware)
  • Unpack the All-in-One
  • Connect the power cord
  • Turn on power
  • Follow the control panel instructions
  • Load plain paper
  • Install the cartridges
  • Align the All-in-One
Setting up a new All-in-One
Follow these steps to set up the product hardware and install the software.
  1. Remove all the tape from the front and back of the product.
    Figure : Remove the packing tape
    Illustration:  Remove the packing tape.
  2. Open the access door, and then remove all the packaging materials from inside the product.
    Figure : Remove the packing tape from inside the product
    Illustration: Remove the packing tape from inside the product.
Step two: Connect the power cord
  1. Connect the power cord to the back of the product, and then connect to the electrical outlet.
    Figure : Connect the power cord
    Illustration: Connect the power cord to the back of the product, and then to the electrical outlet.
Step three: Turn on power
Press the Power button () to turn on the product.
Figure : Press the Power button
Graphic: Press the Power button to turn on power.
Step four: Follow the control panel instructions
  1. Lift the adjustable control panel for easier viewing.
    Figure : Lift the adjustable control panel
    Illustration: Lift the adjustable control panel.
  2. Follow the control panel prompts to finish setting up the product.
    Figure : Product control panel
    Graphic: Control panel display
Step five: Load plain paper
Follow these steps to load paper in the product.
  1. Grasp the lip on the paper tray, and then pull the tray towards you to extend it.
    Figure : Grasp the lip on the paper tray and pull the tray out
    Image:  Grasp the lip of the paper tray.
  2. Slide the paper width guide to its outermost position.
  3. Insert the stack of paper into the input tray with the short edge forward and the print side down.
  4. Push the stack of paper all the way forward, and then adjust the paper width guide so that it rests against the edge of the paper.
    Figure : Push the paper forward in the input tray
    Illustration:  Push the paper forward in the input tray.
  5. Push the tray forward to close it.
Step six: Install the cartridges
Follow these steps to install the cartridges.
  1. Press the Power button () to turn on the product, if it is not already turned on.
  2. Open the access door. The carriage moves to the center of the product. Wait until the carriage is idle and silent before proceeding.
    Figure : Open the access door
    Illustration: Open the access door.
  3. On the new cartridge, pull the pink pull-tab straight back to remove the plastic wrap.
    Figure : Remove the pink tape from the new cartridge
    Illustration: Remove the pink tape from the new cartridge.
  4. Lift the lid on the carriage slot.
    Figure : Lift the lid on the carriage slot
    Illustration: Open the print cartridge lid.
  5. Hold the cartridge at a slight upward angle with the cartridge contacts facing the rear of the product, and then slide the cartridge into the empty slot.
    Make sure that the color of the cartridge matches the color on the cartridge lid.
    • The tri-color cartridge goes in the slot on the left.
    • The black cartridge goes in the slot on the right.
    Figure : Install the cartridge
    Illustration: Install the print cartridge.
  6. Close the lid on the carriage slot to secure the cartridge.
    Figure : Close the lid
    Illustration: Close the cartridge lid.
  7. Repeat these steps to install the other cartridge.
  8. Close the access door. The carriage returns to the right side of the product.
    Figure : Close the access door
    Illustration:  Close the access door.
Step seven: Align the All-in-One
  1. After loading plain white paper, touch Setup () on the product control panel.
  2. Touch Tools, and then touch Align Printer. The alignment process automatically starts, and the alignment page prints.
Figure : Alignment page example
Image:  Alignment page
Getting started with ePrint
Now you can stay connected and productive on the go with ePrint. ePrint lets you print directly to your ePrint-enabled HP printer using a smartphone, notebook, or other mobile device. For additional information related to setting up and using ePrint, click the link provided.
