Compaq Evo n800v Notebook PC - Removing and Replacing Hard Disk Drive
This document is provided to assist in removing and replacing the hard disk drive for the Compaq Evo n800v Notebook PC.
Minimum skill level
Tools required
Small, flat-bladed screwdriver or a flat-bladed alignment tool
Parts required
The replacement part number will vary depending on the hard disk drive that is being replaced. If a part is listed as "Yes" under "Requires Return" then the defective part needs to be returned to HP. Click here for more information on returning parts to HP.
Part Number
Requires Return
20GB ATA-4 hard disk drive - 4,200 RPM, 2.5-inch form factor, 9.5 mm height
285274-001 (Original)
Yes
30GB ATA-4 hard disk drive - 4,200 RPM, 2.5-inch form factor, 9.5 mm height
285275-001 (Original)
Yes
40GB ATA-5 hard disk drive - 4,200 RPM, 2.5-inch form factor, 9.5 mm height
285276-001 (Original)
Yes
40GB ATA 100 EIDE Hard drive - 5400-rpm, 2.5-inch width, 9.5 mm height
301245-001 (Original)
Yes
60GB ATA-5 hard disk drive - 5,400 RPM, 2.5-inch form factor, 12.7 mm height
285277-001 (Original)
Yes
60GB Hard drive
280878-001 (Original)
Yes
Summary of instructions
To view a video demonstrating the procedure for removing the hard disk drive, click on the link below. Or use the product video listing on the HP Services Media Library (Click here to go to HP Service Media Library), then select Hard Disk Drive (HDD) from the menu on the upper left hand side of the screen.
Click here to view the hard disk drive removal video (right-click on the link to open in a new window/tab).
Hard disk drive removal
  2. Remove the black 4 mm Phillips-head screw that secures the hard disk drive.
  3. Use a flat-bladed tool to separate the hard disk drive from the base enclosure.
  4. Pull the hard disk drive out of the bay and remove.
  5. Remove the two black 4 mm Phillips-head screws that secure the drive bezel to the hard disk drive.
  6. Pull the sides of the drive bezel out to release the alignment pins and slide the drive bezel off the hard disk drive.
  7. Place the hard disk drive in a static dissipative bag.
Hard disk drive replacement
  1. Remove the hard disk drive from the static dissipative bag.
  2. Slide the drive bezel onto the hard disk drive and align the alignment pins on the drive with the alignment holes on the drive bezel.
  3. Replace the two black 4 mm Phillips-head screws that secure the drive bezel to the hard disk drive.
  4. Turn the notebook right side up.
  5. Slide the hard disk drive into the bay and push it in until the connector is seated.
  6. Turn the notebook upside down.
  7. Replace the black 4 mm Phillips-head screw.
