HP Color LaserJet CM1312/CM2320 Multifunction Printer Series - Enabling Cartridge Out Override Feature
How to continue printing when Cartridge has reached estimated end-of-life.
Details
An Order Supplies message appears when a print cartridge is nearing the end of its life. A Replace supplies message appears when the print cartridge has reached its estimated end of life. To ensure optimal print quality, HP recommends replacing a print cartridge when the Replace supplies message appears. Print-quality issues can occur when using a cartridge that has reached its estimated end-of-life, resulting in waste of print media and toner from other cartridges. Replacing a print cartridge when the Replace supplies message appears can prevent this waste.
The Auto continue feature in HP ToolboxFX allows the product to continue using a print cartridge that has reached the recommended replacement point.
Using the Auto continue feature can result in unsatisfactory print quality.
All print defects or supply failures incurred when an HP supply is used in cartridge out override mode will not be considered to be defects in materials or workmanship in the supply under the HP Print Cartridge Warranty Statement.
The Auto continue feature can be enabled or disabled at any time, and it does not have to be re-enabled it when it is installed a new print cartridge. When the Auto continue feature is turned ON, the product automatically continues printing when a print cartridge reaches the recommended replacement level. A Replace Supplies Override In Use message appears while a print cartridge is being used in override mode. When replacing the print cartridge with a new supply, the product deactivates the override mode until another print cartridge reaches the recommended replacement level.
To enable or disable the Cartridge Out Override feature from the printer's Control Panel:
  1. On the product control panel, press Setup (wrench icon).
  2. Use the arrow buttons to select System setup, and then press OK.
  3. Use the arrow buttons to select Print Quality, and then press OK.
  4. Use the arrow buttons to select Replace Supplies, and then press OK.
  5. Select Override out to enable the feature. Select Stop at out to disable it.
To enable or disable the Cartridge Out Override feature from HP ToolboxFx:
  1. Open HP ToolboxFX.
  2. Click the Device Settings folder, and then click System Setup.
  3. Next to Auto continue select On to enable the feature. Select Off to disable it.
