HP 2310e Monitor - Product Specifications
The HP 2310e is a 58.42 cm (23 inch) ultra-thin WLED backlit monitor with liquid crystal display (LCD).
Figure : Photo of the HP 2310e ultra-thin WLED backlit monitor
WH344AA and WH344AS
Features
The HP 2310e ultra-thin WLED backlit monitor has the following features:
  • BrightView Technology enhances clarity and provides brilliant colors
  • 1920 x 1080 factory-set resolution
  • Supports HDMI, DisplayPort and DVI-D video input connectors
  • Supports High-bandwidth Digital Content Protection (HDCP) to prevent transmission of non-encrypted high definition content
  • Plug and Play capability, if supported by your computer system
  • On-screen display (OSD) adjustments for ease of setup and screen optimization
Technical specifications
LCD feature
Specification
Display size
58.42 cm (23 inch) diagonal and viewable image
Panel active area (width x height): 50.97 cm x 28.67 cm (20.07 inches x 11.29 inches)
Display type
TN (LCD) with WLED backlighting
Input terminal
1 HDMI connector
1 DisplayPort connector
1 Dual-link DVI-D connector
Integrated speakers
None
Scanning frequency
Horizontal scan range 24-94 KHz
Vertical scan range 50-76 Hz
Viewing angle
Horizontal viewing angle: 170 degrees
Vertical viewing angle: 160 degrees
Recommended resolution (H x V)
1920 x 1080 @ 60Hz (same as max and native)
Contrast ratio
Up to 1000:1
Dynamic contrast ratio
Up to 8,000,000:1
Dynamic Contrast Ratios up to 8,000,000:1 during video playback only, depending on series of frames or time duration.
Response time
5 ms
Pixel pitch
0.265 mm (horizontal and vertical)
HDCP (High-bandwidth Digital Content Protection)
Support for HDCP enables the monitor to display HDTV resolution if connected through the HDMI or DVI connector. A monitor without HDCP support, or connected through analog VGA, causes the displayed video to be downgraded in quality to a DVD-like resolution that is less than HDTV.
HDCP is also a content protection system. HDCP prevents transmission of non-encrypted high definition content.
Power source - AC/DC adapter
Input rating: 100 to 240V~
frequency: 50~60Hz
Power consumption:32 Watts max power consumption (25 Watts typical power consumption) , <2 Watt energy saving mode
Operating environment
Temperature: 5 degrees C to 35 degrees C (41 degrees F to 95 degrees F)
Humidity: 20% RH through 80% RH (non-condensing)
Storage environment
Temperature: -20 degrees C to 60 degrees C (-4 degrees F to 140 degrees F)
Humidity: 5% RH through 95%, RH (non-condensing)
Dimensions
H x W x D (unpacked):
40.80 x 55.80 x 14.90 cm (16.46 x 21.97 x 5.87 inches)
Unpacked: 4.3 Kg (9.5 lbs)
