HP 4410t Mobile Thin Client - Removing and Replacing the Switch Cover
This document is provided to assist in removing and replacing the switch cover for the HP 4410t Mobile Thin Client.
Minimum skill level
Tools required
Small, Phillips-head (P000, P00 and P1) screwdrivers
Parts required
The replacement part number will vary depending on the switch cover that is being replaced. If a part is listed as "Yes" under "Requires Return" then the defective part needs to be returned to HP.
Part Number
Requires Return
Switch cover (Black) - for use on models with 14-inch displays
535860-001 (Modified)
No
Summary of instructions
To view a video demonstrating the procedure for removing the switch cover, click on the link below. Or use the product video listing on the HP Services Media Library, (Click here to go to HP Service Media Library), then select Switch cover from the menu on the upper left hand side of the screen.
Click here to view the switch cover removal video (right-click on the link to open in a new window/tab).
Switch cover removal
  2. Remove the two 3 mm P1 Phillips broad head screws in the battery bay that secure the switch cover to the base enclosure.
  3. Remove the two Phillips-head screws in the rear of the battery bay that secure the switch cover to the base enclosure.
    The video shows a preproduction model of the notebook. The final version of the notebook will include these screws.
  4. Remove the two 3 mm P00 Phillips-head screws from the rear panel that secure the switch cover to the base enclosure.
  5. Turn the notebook right side up and open the display fully.
  6. Slide the switch cover towards the rear of the notebook.
  7. Remove the switch cover from the base enclosure.
Switch cover replacement
  1. Place the switch cover onto the base enclosure.
  2. Align the sides, hinge cut outs, and toes with the sides, hinges, and slots of the base enclosure.
  3. Press down on the switch cover and slide it towards the center of the notebook.
  4. Close the display and turn the notebook upside down.
    Ensure that the four tabs on the rear edge of the switch cover are properly seated in their respective notches in the battery bay.
  5. Replace the two 3 mm P00 Phillips-head screws into the rear panel that secure the switch cover to the base enclosure.
  6. Replace the two Phillips-head screws into the rear of the battery bay that secure the switch cover to the base enclosure.
  7. Replace the two 3 mm P1 Phillips broad head screws into the battery bay that secure the switch cover to the base enclosure.
