    Apache Log4j Update
HP Designjet 111 Printer Series - Avoid paper jams
Avoid paper jams
Your printer is designed for trouble-free use. Paper is unlikely to become jammed inside, but there are a few simple precautions you can take to make it even more unlikely.
  • Make sure nothing is blocking the paper paths.
  • Load the paper correctly, without skew.
  • Do not overload the tray. It holds up to 100 sheets of paper, depending on the paper width. When you load paper into the tray, use the width and length adjusters to avoid the paper skewing.
  • Do not use paper that is curled or crumpled.
  • Use the rear path for thick paper, up to 0.3 mm.
