HP Designjet 111 Printer Series - Supported paper sizes
Roll paper
The minimum width of roll paper is 4.3 in (110 mm) and the maximum width is 24 in (610 mm).
Cut-sheet paper
Width
Length
Thickness
Tray minimum
76 mm
142 mm
Tray maximum (C+)
457 mm
610 mm
Envelopes: 0.4 mm
Other papers: 0.2 mm
Front path minimum
110 mm
205 mm
Front path maximum (A1 oversize)
625 mm
1625 mm
0.2 mm
Rear path minimum
110 mm
205 mm
Rear path maximum (A1 oversize)
625 mm
1625 mm
0.4 mm
