HP Designjet 111 Printer Series - Select paper size
The paper size can be specified in the following ways.
The paper size specified here should be the paper size in which the document was created. It is possible to rescale the document to a different size for printing. See Rescale a printRescale a print.
  • In the Windows driver dialog: select the Paper/Quality tab, then select your paper size from the Size is drop-down list.
  • In the Mac OS Page Setup dialog: select your printer from the Format for list, then select your paper size from the Paper Size list.
    If your application offers no Page Setup dialog, please use the Print dialog.
Custom paper sizes
To choose a non-standard paper size not shown in the list of paper sizes:
  • Under Windows, there are two different ways:
    • In the driver dialog, click the Custom button in the Paper/Quality tab. In the Custom Paper Sizes dialog box, select a name for your custom paper size: you can select Custom 1 to Custom 5. Then specify the paper dimensions, and click Save to save your new paper size.
      The driver will not allow you to create a paper size whose width exceeds its length.
    • From the Start menu, select Control Panel > Printers, then right-click any empty space in the window and select Server Properties. In the Forms tab, check the Create a new form box, specify the name and dimensions of the new form, then click Save Form.
  • Under Mac OS: select Paper Size > Manage Custom Sizes in the Page Setup dialog.
