HP Designjet 111 Printer Series - The roll feed
The roll feed
The roll feed is supplied with the HP Designjet 111 Roll printer. It allows the printer to print on a roll of paper up to 610 mm wide. It includes an automatic cutter.
The roll is loaded from the rear of the printer and must be fed into the rear feed slot.
Once a print job to a roll has finished, the printer will automatically cut the roll. However, the cutter can be disabled from the printer driver. The printer also cuts the roll if you press the OK key.
If a roll of paper is loaded and you want to print to a cut sheet, you must first unload the roll.
