HP Designjet Z5200ps Photo Printer - HP Professional PANTONE Emulation
When you use a named PANTONE color in an image, your application will normally send to the printer a CMYK or RGB approximation to that color. But the application does not take the printer or the paper type into account, it merely produces a generic approximation of the PANTONE color, which will look different on different printers and on different papers.
HP Professional PANTONE Emulation can do a much better job by taking into account the characteristics of the printer and the paper type. The results look as similar to the original PANTONE colors as is possible on a given printer using a given paper type. This technology is designed to produce emulations similar to those set up manually by prepress professionals.
To use HP Professional PANTONE Emulation, all you have to do is to turn it on. In fact, it is normally on by default.
  • In the Windows PostScript driver dialog: go to the Color tab and select HP Professional PANTONE Emulation.
  • In the Mac OS PostScript driver Print dialog: go to the Color Options panel and select HP Professional PANTONE Emulation.
  • On the Embedded Web Server's Submit Job page: select Color > HP Professional PANTONE Emulation.
HP Professional PANTONE Emulation is available only when printing a PostScript or PDF job.
You can also use the Embedded Web Server to print a swatch book showing emulations of PANTONE colors as made by your printer, together with a measure of the color difference (ΔE) between each emulation and the original PANTONE spot color. So HP Professional PANTONE Emulation not only provides the closest match that can be achieved on your printer; it also gives clear information on how close the emulation is to the original spot color.
To print a swatch book, select the Embedded Web Server's Main tab, then HP Professional PANTONE Emulation. Select the strips from different PANTONE Formula Guide tabs that you would like to print, then press the Next button. Check the strips that you have selected. Then press the Print button to print the swatch book.
Figure : Swatch book example
