HP Pavilion 2210m Monitor - Product Specifications
The HP Pavilion 2210m is a 54.6 cm (21.5 inch) Full HD wide-screen monitor with liquid crystal display (LCD) and thin-film transistor (TFT) screen.
Figure : Photo of the HP Pavilion 2210m Full HD LCD wide-screen monitor
WB988AA or WB988AS
Features
The HP Pavilion 2210m Full HD LCD wide-screen monitor has the following features:
  • BrightView Technology enhances clarity and provides brilliant colors
  • 1920 x 1080 factory-set resolution
  • Supports HDMI, DVI-D and VGA video input connectors
  • Supports High-bandwidth Digital Content Protection (HDCP) to prevent transmission of non-encrypted high definition content
  • Plug and Play capability, if supported by your computer system
  • On-screen display (OSD) adjustments for ease of setup and screen optimization
Technical specifications
LCD feature
Specification
Display size
54.6 cm (21.5 inch) diagonal and viewable image
Panel active area (width x height): 47.67 cm x 26.82 cm (18.77 inches x 10.56 inches)
Display type
Thin-Film Transistor LCD active matrix
BrightView technology
Input terminal
1 DVI-D connector
1 HDMI connector
1 VGA connector
Integrated speakers
2 watts per channel
Scanning frequency
Horizontal scan range 24-94 KHz
Vertical scan range 50-76 Hz
Viewing angle
Horizontal viewing angle: 170 degrees
Vertical viewing angle: 160 degrees
Recommended resolution (H x V)
1920 x 1080 @ 60Hz (same as max and native)
Contrast ratio
Up to 1000:1
Dynamic contrast ratio
Up to 40,000:1 (typical)
Dynamic Contrast Ratios up to 40,000:1 during video playback only, depending on series of frames or time duration.
Response time
2.5 ms (typical)
Pixel pitch
0.248 mm
HDCP (High-bandwidth Digital Content Protection)
Support for HDCP enables the monitor to display HDTV resolution if connected through the HDMI or DVI connector. A monitor without HDCP support, or connected through analog VGA, causes the displayed video to be downgraded in quality to a DVD-like resolution that is less than HDTV.
HDCP is also a content protection system. HDCP prevents transmission of non-encrypted high definition content.
Power source - AC/DC adapter
Input rating: 100 to 240V~
frequency: 50~60Hz
Power consumption:56 Watts max power consumption (42 Watts typical power consumption) , <2 Watt energy saving mode
Operating environment
Temperature: 5 degrees C to 35 degrees C (41 degrees F to 95 degrees F)
Humidity: 20% RH through 80% RH (non-condensing)
Storage environment
Temperature: -20 degrees C to 60 degrees C (-4 degrees F to 140 degrees F)
Humidity: 5% RH through 95% RH (non-condensing)
Dimensions
H x W x D (unpacked):
39.11 x 56.13 x 20.06 cm (15.4 x 22.1 x 7.9 inches)
Unpacked: 5.52 Kg (12.17 lbs)
