    Looking for Site Help?
HP 104-in Dual Roll Kit - Load rolls onto the spindle
The dual-roll spindle is marked to assist you in positioning the differential hub.
Loading the dual-roll spindles
  1. Ensure that the differential hubs on the input and output spindles are aligned with each other.
  2. When both differential hubs are correctly positioned, use an Allen key 6 to tighten the screws and secure them in place. If a differential hub is loose, the substrate could become skewed during printing.
    You should tighten the screw until the washer touches the bolt. If you can still see the yellow spring, tighten the screw further.
  3. At each end of the spindle, unscrew and remove the outer parts of the hub, using an Allen key 4.
  4. Unscrew and remove the inner part of each hub.
  5. Insert the first roll on the spindle.
  6. Replace the hub, and secure it with the Allen key.
  7. Insert the second roll on the spindle.
  8. Replace the hub, and secure it with the Allen key.
  9. Ensure that the end of the right-hand roll is located within the maximum allowed distance from the right-hand end of the spindle: it should be between the gear and the dashed line.
  10. Ensure that the roll core fits tightly on the hub.
  11. Ensure that the roll core fits tightly on the differential hub.
  12. Load the spindle at the rear of the printer, and secure the spindle latches.
  13. Use the same process to load the output spindle at the front of the printer, but load the spindle with two empty cores to receive the printed substrate.
Country: Flag Serbia
