Compaq Evo n610c Notebook PC - Removing and Replacing the Battery
This document is provided to assist in removing and replacing the battery for the Compaq Evo n610c Notebook PC.
Minimum skill level
Parts required
The replacement part number will vary depending on the battery that is being replaced. If a part is listed as "Yes" under "Requires Return" then the defective part needs to be returned to HP. Click here for more information on returning parts to HP.
Part Number
Requires Return
Battery (Primary) - 8-cell lithium-ion (Li-Ion)
232633-001 (Original)
Yes
Battery (Primary) - 8-cell lithium-ion (Li-Ion), 14.4 V dc, 4.4 Ah
301952-001 (Original)
Yes
For customers in countries/regions with RoHS legislation* (e.g. EU, China, etc.) restricting the use of hazardous substances in electrical equipment. The use of the Original Spare part is regulated by RoHS legislation. If your unit contains a part that is labeled with the Modified Spare number, the Modified Spare must be ordered as the replacement part. If your unit contains a part that is labeled with the Original Spare number, please order the Original Spare as the replacement part. In this case either the Original Spare or the Modified Spare may be shipped which will not affect performance or functionality of the unit.
Summary of instructions
To view a video demonstrating the procedure for removing the battery, click on the link below. Or use the product video listing on the HP Services Media Library (Click here to go to HP Service Media Library), then select Battery from the menu on the upper left hand side of the screen.
Click here to view the battery removal video (right-click on the link to open in a new window/tab).
Battery removal
  2. Slide and hold the battery release latch to the unlock position.
  3. Use your finger to lift the battery up and out.
Battery replacement
  1. Toe the battery into the notebook.
  2. Press the battery into the base enclosure until you hear a click.
