    Fix HP Printer issue on macOS
HP Scitex LX Printer Family - Edit a substrate preset
To edit the technical characteristics of a custom substrate type, go to the HP Internal Print Server and select Substrate > Edit. This allows you to change the settings in the substrate preset, exactly as when creating a new preset. See Fine-tune the settings in your new preset.
Only custom substrates can be edited.
