    We are upgrading our website
HP Z200 Small Form Factor Workstation - Computer specifications
This section provides computer chassis, power supply, and environmental specifications.
Physical characteristics
The following table lists the computer physical characteristics.
Weight (Typical configuration)
7.6 kg (16.72 lb.)
Chassis Dimensions
Height: 10.0 cm (3.95 in.)
Width: 33.8 cm (13.0 in.)
Depth: 37.9 cm (14.9 in.)
Power supply description
The computer includes a 240W 89% efficient power supply to provide power for the computer. The power supply is compatible with ENERGY STAR Ver. 5 requirements.
Power supply voltages
Power supply source voltages
Source voltage
+12 V-CPU
Input to onboard regulator that supplies power to CPU
+12 V-MAIN
PCI, PCIe, system fans, storage (optical and hard disk drives), and input to onboard regulators
+12 V-SBY
Input to onboard regulators
V12N
PCI and serial ports
Power supply currents
Maximum current per rail
Output (240W)
+12V Main
+12Vcpu
–12V
12Vsb
Nominal output voltage
12.1
12.1
-12.0
11.4
Maximum continuous current
14A
12A
0.15A
1.3A
240W combined
Do not exceed 240 watts of total continuous output power.
Maximum combined current on +12V(CPU,Main) is 20A.
Power supply specifications
Item
Power supply
240W Wide Ranging, Active PFC and 89% efficient
Operating voltage range
90 – 264 VAC
Rated voltage range
100–240 VAC
Rated line frequency
50–60 Hz
Operating line frequency range
47–63 Hz
Rated input current
4A
Heat dissipation
(Configuration and software dependent)
Typical 170 BTU/hr = (42.87 kg-cal/hr)
Maximum 1063 BTU/hr = (206.27 kg-cal/hr)
Power supply fan
One fan, 92mm x 25mm, variable speed
FEMP Standby Power compliant @115V (<2W in S5 – Power Off)
Yes
ERP Lot 6 (EuP) compliant @230V (<1w in S5 – Power Off)
Yes
Built-in Self Test LED
No
Surge tolerant full ranging power supply (withstands power surges up to 2000V)
Yes
Power Consumption in sleep mode (as defined by ENERGY STAR) - Suspend to RAM (S3) (Instantly Available PC)
<6 watts
Power consumption and heat dissipation
Power consumption and heat dissipation specifications are available for multiple configurations. To review available specifications, see http://www.hp.com/go/quickspecs.
To reach zero power consumption, unplug the computer from the power outlet or use a power strip with an on/off switch. For additional information about power-saving features, see the operating system installation instructions.
This product is in compliance with U.S. Executive Order 13221.
System fans
This computer includes:
  • One front system fan
  • One power supply fan
In addition, some graphics cards include onboard fans.
Resetting the power supply
If an overload triggers the power supply overload protection, power is immediately disconnected.
To reset the power supply:
  1. Disconnect the power cord from the computer.
  2. Determine what caused the overload and fix the problem. For troubleshooting information, see Diagnostics and troubleshooting.
  3. Reconnect the power cord and restart the computer.
When you power off the computer through the operating system, power consumption falls below what is considered low power consumption but does not reach zero. This low power consumption feature extends the life of the power supply.
Environmental specifications
The following table lists the environmental specifications of HP Workstations.
HP Workstation environmental specifications
Temperature
Operating: 5 to 35°C (40 to 95°F)
Non-operating: -40 to 60°C (-40 to 140°F)
Derate by one degree C (1.8 degrees F) for every 305m (1,000 ft.) altitude over 1,524m (5,000 ft.).
Humidity
Operating: 8 to 85% Relative Humidity (RH), non-condensing
Non-operating: 8 to 90% Relative Humidity, non-condensing
Altitude
Operating: 0 to 3,048m (10,000 ft.)
Non-operating: 0 to 9,144m (30,000 ft.)
Shock
Operating: ½-sine: 40g, 2-3ms
Non-operating:
  • ½-sine: 160 cm/s, 2-3ms (~100g)
  • square: 422 cm/s, 20g
Values represent individual shock events and do not indicate repetitive shock events.
Vibration
Operating Random: 0.5g (rms), 5-300 Hz
Non-Operating: random: 2.0g (rms), 10-500 Hz
Values do not indicate continuous vibration.
ENERGY STAR Qualification
HP computers marked with the ENERGY STAR logo are compliant with the applicable U.S. Environmental Protection Agency (EPA) ENERGY STAR specifications for computers. The EPA ENERGY STAR logo does not imply endorsement by the EPA. As an ENERGY STAR Partner, Hewlett-Packard Company has determined the products marked with the ENERGY STAR logo are ENERGY STAR qualified per the applicable ENERGY STAR guidelines for energy efficiency. The following logo appears on all ENERGY STAR qualified computers.
The ENERGY STAR Computers Program was created by the EPA to promote energy efficiency and reduce air pollution through more energy-efficient equipment in homes, offices, and factories. One way products achieve this energy efficiency is by reducing power consumption when not being used through the Microsoft Windows Power Management feature.
The Power Management feature enables the computer to enter a low-power (or “sleep”) mode after a period of inactivity. When used with an external monitor that is ENERGY STAR qualified, this feature also supports the similar power management features of the external monitor.
To take advantage of this energy savings:
  • The Power Management feature has been preset to suspend the computer to a sleep state after 30 minutes of inactivity.
  • The Power Management feature has been preset to suspend the monitor to a sleep state after 15 minutes of inactivity.
Both the computer and monitor can be woken from sleep mode through user interaction with any of the computer input devices (mouse, keyboard, and so on). when configured with Wake On LAN (WOL) enabled, the computer can also be woken by a network signal.
See the EPA ENERGY STAR Power Management Web site for more information about the energy and financial savings potential of the Power Management Feature: http://www.energystar.gov/powermanagement.
See the EPA ENERGY STAR Web site for more information about the ENERGY STAR program and its environmental benefits: http://www.energystar.gov.
Using the Energy Save Monitor feature with monitors that are not ENERGY STAR qualified can cause video distortion when an Energy Save timeout occurs.
ENERGY STAR is not supported on Linux computers.
If it is necessary to restore the operating system, you must also reset the ENERGY STAR settings (if applicable) after the restore.
To verify the factory default power settings for your computer, select Start>Control Panel, and then double-click Power Options.
ERP compliance mode
This computer provides ERP compliance mode capability.
When enabled, this feature enables the computer to shut down to the lowest possible power state by removing all power to the system board.
When disabled, the computer powers down conventionally.
When the computer is shut down in ERP compliance mode, it must be powered up with the computer power button.
Enabling ERP compliance mode
To enable ERP compliance mode:
  1. Press F10 during start up.
  2. Using the arrow keys, select the Power>Hardware Power Management>ERP Compliance Mode, and then select Enable.
  3. Press F10 to accept the change.
  4. Select File>Save Change and Exit, and then press F10 to accept the change.
Disabling ERP compliance mode
To disable the ERP compliance mode:
  2. Select Power>Hardware Power Management>ERP Compliance Mode, and then select Disable.
Accessibility
HP is committed to developing products, services, and information that is easier to access for all customers, including customers with disabilities and age-related limitations. HP products with Windows® 7, Windows Vista® Business, and Microsoft® Windows® XP Professional preinstalled are designed for accessibility. These products are tested with industry-leading Assistive Technology products. For more information see http://www.hp.com/accessibility.
Hyper-threading
This HP computer supports Hyper-threading.
Hyper-Threading Technology (HTT), is an Intel-proprietary technology used to provide process parallelization . The technology improves processor performance under certain workloads by providing useful work for execution units that would otherwise be idle. A processor with Hyper-Threading enabled is treated by the operating system as two processors instead of one. Hyper-threading relies on support in the operating system as well as the CPU.
SATA Power Management
SATA Power Management enables or disables SATA bus and/or device power management.
Intel Turbo Boost Technology
The HP Z Workstation series supports Intel® Turbo Boost Technology.
This feature enables the CPU to run at a higher than normal rate. When all CPU cores are not necessary for the workload, inactive cores are turned off and power is diverted to the active cores to increase their performance.
Turbo Boost is enabled and disabled in computer BIOS.
HP Cool Tools
An HP computer with Windows XP includes additional software that is not installed when you first start the computer. To access or learn more about these additional preinstalled tools on the computer that can enhance the computer experience:
  1. Open the HP Cool Tools folder by selecting Start>All Programs>HP Cool Tools.
  2. Select the HP Cool Tools icon on the desktop.
  3. To learn more about these applications, select HP Cool Tools—Learn More.
  4. To install or launch the applications, select the appropriate application.
A preinstalled Windows 7 or Windows Vista Business operating system does not contain a Cool Tools icon, shortcut or folder but several of the tool programs are included, such as Performance Tuning Framework.
Ensuring proper ventilation
Proper ventilation for the system is important for computer operation. Follow these guidelines to ensure adequate ventilation:
  • Operate the computer on a sturdy, level surface.
  • Place the computer in an area with adequate ventilation. Provide at least 15.24 CM (6 inches) of clearance at the front and back of the computer as shown in the following figure. (Your computer might look different than the one shown.)
    Figure :
  • Ensure that the ambient air temperature surrounding the computer falls within the published limit.
    The ambient upper limit of 35 C is only good up to 1524 M (5000 FT) elevation. There is a 1 C per 304.8 M (1000 FT) derating above 1524 M (5000 FT). So, at 3,048 M (10,000 FT), the upper ambient air temperature limit is 30 C.
  • For cabinet installation, ensure adequate cabinet ventilation and ensure that the ambient temperature within the cabinet does not exceed published limits.
  • Never restrict the incoming or outgoing airflow of the computer by blocking any vents or air intakes as shown in the following figure.
    Figure :
Country: Flag Serbia
