HP LD4200 and LD4700 LCD Monitors - Technical Specifications
All performance specifications are provided by the component manufacturers. Performance specifications represent the highest specification of all HP's component manufacturers' typical level specifications for performance and actual performance may vary either higher or lower.
HP LD4200 LCD Monitor
HP LD4200 Specifications
Type
106.73 cm
TFT LCD
42 inches
Viewable Image Size
106.73 cm diagonal
42-inch diagonal
Pixel Pitch
0.681 mm x 0.681 mm
Maximum Weight
Without Stand & Speaker
With Speaker
With Stand
With Stand & Speaker
21.2 kg
21.9 kg
24.5 kg
25.3 kg
46.7 lbs.
48.3 lbs.
54.0 lbs.
55.7 lbs.
Dimensions (Without Stand & Speaker)
Height
Depth
Width
58.76 cm
11.39 cm
99.56 cm
23.1 inches
4.5 inches
39.2 inches
Dimensions (With Speaker)
Height
Depth
Width
58.76 cm
12.57 cm
99.56 cm
23.1 inches
4.9 inches
39.2 inches
Dimensions (With Stand)
Height
Depth
Width
67.6 cm
29.3 cm
99.56 cm
26.6 inches
11.5 inches
39.2 inches
Dimensions (With Stand & Speaker)
Height
Depth
Width
67.6 cm
29.3 cm
99.56 cm
26.6 inches
11.5 inches
39.2 inches
Power
Rated Voltage
AC 100-240V ~50/60Hz 2.2 A
Power Consumption
On Mode
Sleep Mode
Off Mode
220W Typical
≤ 1W (RGB) / 4W (HDMI/DVI)
≤ 1W
Maximum Resolution
RGB
HDMI/DVI
1920 x 1080 @ 60Hz
1920 x 1080 @ 60Hz (if supported by OS or video card type)
Recommended Resolution
RGB
HDMI/DVI
1920 x 1080 @ 60Hz
Horizontal Frequency
RGB
HDMI/DVI
30 - 83kHz
30 - 83kHz
Vertical Frequency
RGB
HDMI/DVI
56 - 76Hz
56 - 60Hz
Synchronization Type
Composite/Separate/Digital
Input Connector
15-pin D-Sub type, HDMI (digital), S-Video, Composite Video, Component, RS-232C
Environmental Conditions
Operating Temperature
Storage Temperature
0 ~ 35° C, Humidity 10% ~ 80%
-20 ~ 60° C, Humidity 5% ~ 90%
Audio (Select Models)
RMS Audio Output
Input Sensitivity
Speaker Impedance
10W + 10W (R+L)
0.7 rms
8 Ohms
HP LD4700 LCD Monitor
HP LD4700 Specifications
Type
119.28 cm
TFT LCD
47 inches
Viewable Image Size
119.28 cm diagonal
47-inch diagonal
Pixel Pitch
0.5415 mm x 0.5415 mm
Maximum Weight
With Speaker
With Stand
26.58 kg
27.33 kg
30.06 kg
31.34 kg
58.6 lbs.
60.25 lbs.
67.5 lbs.
69.1 lbs.
Height
Depth
Width
66.10 cm
11.87 cm
111.70 cm
26.02 inches
4.67 inches
43.98 inches
Height
Depth
Width
66.10 cm
11.87 cm
111.70 cm
26.02 inches
4.67 inches
43.98 inches
Height
Depth
Width
75.78 cm
30.26 cm
111.70 cm
29.83 inches
11.91 inches
43.98 inches
Height
Depth
Width
75.78 cm
30.26 cm
111.70 cm
29.83 inches
11.91 inches
43.98 inches
Power
Rated Voltage
AC 100-240V ~50/60Hz 3.0 A
Power Consumption
On Mode
Sleep Mode
Off Mode
300W Typical
≤ 1W
Maximum Resolution
RGB
HDMI/DVI
1920 x 1080 @ 60Hz
RGB
HDMI/DVI
1920 x 1080 @ 60Hz
RGB
HDMI/DVI
30 - 83kHz
30 - 83kHz
Vertical Frequency
RGB
HDMI/DVI
56 - 76Hz
56 - 60Hz
Input Connector
Storage Temperature
RMS Audio Output
Input Sensitivity
Speaker Impedance
10W + 10W (R+L)
0.7 rms
8 Ohms
Recognizing Preset Display Resolutions
The display resolutions listed below are the most commonly used modes and are set as factory defaults. This monitor automatically recognizes these preset modes and they will appear properly sized and centered on the screen.
HP LD4200 and LD4700 Preset Display Modes
HP LD4200 and LD4700 Factory Preset Display Modes
Preset
Pixel Format
Horz Freq (kHz)
Vert Freq (Hz)
1
720 x 400
31.468
70.8
*2
640 x 480
31.469
59.94
3
640 x 480
37.5
75
*4
800 x 600
37.879
60.317
5
800 x 600
46.875
75
6
832 x 624
49.725
74.55
*7
1024 x 768
48.363
60
8
1024 x 768
60.123
75.029
*9
1280 x 720
44.772
59.855
*10
1280 x 1024
63.981
60.02
11
1280 x 1024
79.98
75.02
*12
1600 x 1200
75
60
*13
1680 x 1050
65.290
60
*14
1920 x 1080
67.5
60
1 ~14 RGB Mode
* HDMI/DVI Mode
DTV Mode
Component
HDMI/DVI (DTV)
480i
o
x
480p
o
o
576i
o
x
576p
o
o
720p
o
o
1080i
o
o
1080p
o
o
DTV/PC selection on RGB and HDMI/DVI inputs is available for PC resolutions 640 x 480/60Hz, 1280 x 720/60Hz, 1920 x 1080/60Hz and DTV resolutions: 480p, 720p, 1080p.
Power Indicator
Mode
Indicator Light
On Mode
Blue
Sleep Mode
Amber
Off Mode
Country: Flag Serbia
