    Fix Windows 10 Update Issues
HP Color LaserJet CM3530 Multifunction Series Printer - Customer Self Repair Parts
Customer Self-Repair (CSR) parts are available for many HP LaserJet products to reduce repair time. The following information provides information about the CSR program and identifies the parts that are available for customer self-repair.
You can learn more about the customer self-repair program at http://www.hp.com/go/selfrepair.
Frequently Asked Questions are available on the FAQ page at http://www.hp.com/go/csr-faq.
The Customer Self Repair support flyer is available at http://www.hp.com/go/csr-support.
Information about CSR standard warranty terms and conditions can be found in the box with the product or see the CSR LaserJet Warranty statement at http://www.hp.com/go/csr-ljwarranty.
Customer Self-Repair Parts
Item
Self - Replacement Options *
Control panel overlay/labels
Mandatory
Formatter
Mandatory
Fuser 110V/220V
Mandatory
ETB/ITB
Mandatory
Pick Rollers Tray 2-x
Mandatory
Feed Rollers Tray 2-x
Mandatory
Transfer Roller/Tray 2
Mandatory
Separation Pads/Rollers
Optional
ADF Roller Kit
Mandatory
Cassettes
Mandatory
Memory
Mandatory
Firmware DIMM/CF
Mandatory
Power Cords
Mandatory
Toner Cartridges
Mandatory
Fax Cards
Mandatory
EIO JetDirect cards
Mandatory
Hard disk drives
Mandatory
Staple Cartridges
Mandatory
ADF Assembly
Mandatory
Control Panel
Optional
ADF Roller Kit
Mandatory
* 'Mandatory' indicates on-site or return-to-depot support is not provided under your HP product warranty. Parts labeled 'Mandatory' are to be installed by the customer unless the customer is willing to pay HP service personnel to perform the repair.
'Optional' parts items may be installed by HP service personnel at the customer's request at no additional charge during the product warranty period.
