Compaq tc1000 Tablet PC - Removing and Replacing the Hard Disk Drive (HDD)
This document is provided to assist in removing and replacing the hard disk drive (HDD) for the Compaq tc1000 Tablet PC.
Minimum skill level
Tools required
Small, Phillips-head P0 screwdriver
Parts required
The replacement part number will vary depending on the hard disk drive that is being replaced. If a part is listed as "Yes" under "Requires Return" then the defective part needs to be returned to HP. Click here for more information on returning parts to HP.
Part Number
Requires Return
30GB SMART technology hard disk drive
310668-001 (Original)
Yes
40GB hard drive - 5,400 RPM
311240-001 (Original)
Yes
60GB hard drive - 5,400 RPM
317901-001 (Original)
Yes
Summary of instructions
To view a video demonstrating the procedure for removing the hard disk drive, click on the link below. Or use the product video listing on the HP Services Media Library, (Click here to go to HP Service Media Library) then select Hard Disk Drive (HDD) from the menu on the upper left hand side of the screen.
Click here to view the hard disk drive removal video (right-click on the link to open in a new window/tab).
Hard disk drive removal
  2. Remove the two 4 mm Phillips-head screws that secure the hard disk drive cover.
  3. Use your finger to lift the inside edge of the hard disk drive cover and remove it.
  4. Grasp the plastic tab and pull to disengage the drive from the system board connector.
  5. Lift the drive and remove it.
  6. Place the hard disk drive in a static dissipative bag.
Hard disk drive replacement
  1. Remove the hard disk drive from the static dissipative bag.
  2. Insert the drive into the bay and slide it toward the center of the tablet PC until the connector is seated.
  3. Tuck the plastic tab down into the enclosure.
  4. Toe the hard disk drive cover into the tablet PC.
  5. Replace the two 4 mm Phillips-head screws.
