HP Compaq tc1100 Tablet PC - Removing and Replacing the Hard Disk Drive
This document is provided to assist in removing and replacing the hard disk drive for the HP Compaq tc1100 Tablet PC.
Minimum skill level
Tools required
Small Phillips-head P0 screwdriver.
Parts required
The replacement part number will vary depending on the hard disk drive that is being replaced. If a part is listed as "Yes" under "Requires Return" then the defective part needs to be returned to HP. Click here for more information on returning parts to HP.
Part Number
Requires Return
30GB ATA-133 IDE hard drive - 4,200 RPM, 2.5 in form factor (9.5 mm height)
348339-001 (Original)
Yes
40GB ATA-133 IDE hard drive - 4,200 RPM, 2.5 in form factor (9.5 mm height)
348340-001 (Original)
Yes
40GB ATA-133 IDE hard drive - 5,400 RPM, 2.5 in form factor (9.5 mm height)
374025-001 (Original)
Yes
60GB ATA-133 IDE hard drive - 5,400 RPM, 2.5 in form factor (9.5 mm height)
348341-001 (Original)
Yes
80GB ATA-133 IDE hard drive - 5,400 RPM, 2.5 in form factor (9.5 mm height)
366786-001 (Original)
Yes
For customers in countries/regions with RoHS legislation* (e.g. EU, China, etc.) restricting the use of hazardous substances in electrical equipment. The use of the Original Spare part is regulated by RoHS legislation. If your unit contains a part that is labeled with the Modified Spare number, the Modified Spare must be ordered as the replacement part. If your unit contains a part that is labeled with the Original Spare number, please order the Original Spare as the replacement part. In this case either the Original Spare or the Modified Spare may be shipped which will not affect performance or functionality of the unit.
Summary of instructions
To view a video demonstrating the procedure for removing the hard disk drive, click on the link below. Or use the product video listing on the HP Services Media Library (Click here to go to HP Service Media Library), then select Hard disk drive from the menu on the upper left hand side of the screen.
Click here to view the hard disk drive removal video (right-click on the link to open in a new window/tab).
Hard disk drive removal
  2. Remove the two 4 mm Phillips-head screws that secure the hard disk drive cover.
  3. Use your finger to lift the inside edge of the hard disk drive cover and remove it.
  4. Grasp the plastic tab and pull to disengage the drive from the system board connector.
  5. Lift the drive and remove it.
  6. Place the hard disk drive in a static dissipative bag.
Hard disk drive replacement
  1. Remove the hard disk drive from the static dissipative bag.
  2. Insert the drive into the bay and slide it toward the center of the tablet PC until the connector is seated.
  3. Tuck the plastic tab down into the enclosure.
  4. Toe the hard disk drive cover into the tablet PC.
  5. Replace the two 4 mm Phillips-head screws.
Parts return
