HP Compaq tc1100 Tablet PC - Removing and Replacing the Docking Station
This document is provided to assist in removing and replacing the docking station for the HP Compaq tc1100 Tablet PC.
Minimum skill level
Parts required
The replacement part number will vary depending on the docking station that is being replaced. If a part is listed as "Yes" under "Requires Return" then the defective part needs to be returned to HP. Click here for more information on returning parts to HP.
Part Number
Requires Return
HP Tablet PC docking station
348338-001 (Original)
Yes
For customers in countries/regions with RoHS legislation* (e.g. EU, China, etc.) restricting the use of hazardous substances in electrical equipment. The use of the Original Spare part is regulated by RoHS legislation. If your unit contains a part that is labeled with the Modified Spare number, the Modified Spare must be ordered as the replacement part. If your unit contains a part that is labeled with the Original Spare number, please order the Original Spare as the replacement part. In this case either the Original Spare or the Modified Spare may be shipped which will not affect performance or functionality of the unit.
Summary of instructions
To view a video demonstrating the procedure for removing the docking station, click on the link below. Or use the product video listing on the HP Services Media Library (Click here to go to HP Service Media Library), then select Docking station from the menu on the upper left hand side of the screen.
Click here to view the docking station removal video (right-click on the link to open in a new window/tab).
Docking station installation
    Before installing the tablet PC on the docking station, ensure that the docking station stand is in the vertical or portrait and writing position and that the keyboard on the tablet PC is in the closed and locked position.
  2. Align the alignment slots on the bottom edge of the tablet PC with the alignment brackets on the docking station stand.
  3. Place the tablet PC into the docking station stand.
  4. Press down on the tablet PC to connect it to the docking station stand.
Docking station removal
  1. Pull out on the docking station stand release handle.
  2. Lift the top edge of the tablet PC to disconnect it from the docking station stand connector.
  3. Remove the tablet PC from the docking station stand.
Parts return
