HP Compaq nc6220 Notebook PC - Removing and Replacing Wireless LAN Mini PCI card
This document is provided to assist in removing and replacing the wireless LAN mini PCI card for the HP Compaq nc6220 Notebook PC.
Minimum skill level
The End-User should possess product-specific knowledge and technical skill on how to service the system, and have familiarity with the operating system.
Tools required
  • Small, smooth-tipped needlenose pliers
  • Smooth jaw, bent-tipped needlenose pliers (optional)
Parts required
The replacement part number will vary depending on the wireless LAN mini PCI card that is being replaced. If a part is listed as "Yes" under "Requires Return" then the defective part needs to be returned to HP. Click here for more information on returning parts to HP.
Part Number
Requires Return
Mini PCI 802.11b/g wireless LAN (WLAN) card (Broadcom) - Supports IEEE 802.11b/g wireless standards - Maximum data rate of up to 11Mbps for 802.11b or 54Mbps for 802.11g (International)
373032-002 (Original)
Yes
Mini PCI 802.11b/g wireless LAN (WLAN) card (Broadcom) - Supports IEEE 802.11b/g wireless standards - Maximum data rate of up to 11Mbps for 802.11b or 54Mbps for 802.11g (Japan)
373032-291 (Original)
Yes
Mini PCI 802.11b/g wireless LAN (WLAN) card (Broadcom) - Supports IEEE 802.11b/g wireless standards - Maximum data rate of up to 11Mbps for 802.11b or 54Mbps for 802.11g - (United States)
373032-001 (Original)
Yes
Mini PCI 802.11a/b/g wireless LAN (WLAN) card - Supports IEEE 802.11a/b/g wireless standards (Europe, Middle East, and Africa)
373900-021 (Original)
Yes
Mini PCI 802.11a/b/g wireless LAN (WLAN) card - Supports IEEE 802.11a/b/g wireless standards (Japan)
373900-291 (Original)
Yes
Mini PCI 802.11a/b/g wireless LAN (WLAN) card - Supports IEEE 802.11a/b/g wireless standards (International)
373033-002 (Original)
Yes
373033-291 (Original)
Yes
Mini PCI 802.11a/b/g wireless LAN (WLAN) card - Supports IEEE 802.11a/b/g wireless standards (most-of-world)
373900-001 (Original)
Yes
Mini PCI 802.11a/b/g wireless LAN (WLAN) card - Supports IEEE 802.11a/b/g wireless standards (United States)
373033-001 (Original)
Yes
Mini PCI 802.11a/b/g 'High Band' wireless LAN (WLAN) card - Supports IEEE 802.11a/b/g wireless standards (rest-of-world)
373901-001 (Original)
Yes
Summary of instructions
To view a video demonstrating the procedure for removing the wireless LAN mini PCI card, click on the link below. Or use the product video listing on the HP Services Media Library (Click here to go to HP Service Media Library), then select Wireless LAN Mini PCI car from the menu on the upper left hand side of the screen.
Click here to view the wireless LAN mini PCI card removal video (right-click on the link to open in a new window/tab).
Wireless LAN mini PCI card removal
  2. Carefully disconnect the two wireless antenna cables from the Mini PCI card with a small needlenose pliers or tweezers.
    Use care when disconnecting the wireless antenna cables from the Mini PCI card. Damaged cables or connectors can degrade notebook performance.
  3. Push both arms outward simultaneously to release the Mini PCI card to the spring tension position.
  4. Grasp the Mini PCI card by the edges and pull gently to remove it.
  5. Place the Mini PCI card in a static dissipative bag.
Wireless LAN mini PCI card replacement
  1. Remove the Mini PCI card from the static dissipative bag.
  2. Locate the alignment slot and align it to the board receptacle.
  3. Grasp the Mini PCI card by the edges and push gently to replace it.
  4. Press the Mini PCI card down to latch the arms.
  5. Reconnect the two wireless antenna cables to the Mini PCI card.
    Use care when connecting the wireless antenna cables to the Mini PCI card. Damaged cables or connectors can degrade notebook performance.
Parts return
